key fob coding?
Old Jul 30, 2007 | 12:24 AM
  #21
Nottm_S2's Avatar
i can't get this to work either
it would appear to go into learn mode (the indicators all stay lit up)
but it ignores the new remote
Old Nov 12, 2007 | 09:30 AM
  #22
Kiwi-S2000's Avatar
Hi all.
None of the above works for a JDM 2 button remote
Any more ideas
Kiwi
Old Sep 8, 2009 | 02:15 PM
  #23
ColinG's Avatar
Thread resurrection time...
My MY06 car only came with one 3 button remote fob, but I've recently picked up a second used one to have as a spare.
Anyway, trying to programme it earlier this evening as per the method above (turn ignition on, press fob button, ignition off, repeat etc.) I can't seem to programme the other remote in. I've got the process right as I managed to disable my original remote by accident and then reprogrammed it fine, but the new one won't play ball. The little red light on the end flashes when I press a button so the battery appears to be OK.
Are all 3 button remotes compatible does anyone know? The stickers on the back have a different layout but the frequency and CE marking are the same. There's a 6 digit code that is different (remote serial number?) and another code, my original is G8D-453-H-A, the other one is G8D-345-H-A.
Any ideas?
Old Sep 9, 2009 | 08:36 AM
  #24
mikey P's Avatar
i learnt from trial and error that only the fob with 453 could be coded to work with my 2001 car, tried two other fobs with different codes (cant recall the numbers but they didnt work). maybe this is the same to all years?
Old Sep 9, 2009 | 09:35 AM
  #25
outtametree's Avatar
This is for my 2 button remote, have fun...
08E56 CAT 88801
(CAT 1 T2)
HANDSET LEARNING INSTRUCTIONS
Please hand this instruction booklet
to the owner of the vehicle
08E56 CAT 88801
(CAT 1 T2)
Unlike the CAT 1 T1 (08E50 CAT 88801) the CAT 1 T2
(08E56 CAT 88801) does not need a RED MASTER KEY
The simplest way to distinguish between a T1 and a T2 is
that the T1 Central Locking Locks after the fourth flash
of the vehicle indicators when the handset is pressed and
the T2 the locks immediately, with the first flash of the
traffic indicators, when the handset is pressed.
Handset Learning Procedure
The handsets are designed to transmit a new code with
each press of the button. Regardless of the number of
codes analysed, a pattern cannot be identified
GoldLude
Nov 2, 2011 02:31 PM
S2k4mee
Apr 23, 2011 12:34 PM
s2000honduras
Jun 4, 2008 12:36 PM
ED1
Dec 23, 2005 02:35 PM
Rspec99
Mar 14, 2002 09:06 PM
