KN FIPK for 08 S2K
KN FIPK for 08 S2K
I've found this KN FIPK i'm going to buy but in the description it says 00 > 07? Mines an 08 and when you use KN's website and put in 08 Honda S2000 it says theres nothing available, thats a mistake right? This one will fit my 2008?
http://www.amazon.co.uk/dp/B000E5S4Z...A3P5ROKL5A1OLE
Brilliant, The part is ordered and should come tomorrow! Gonna have to buy a step drill bit though too now.. or a screw driver Is there a specific step drill size i need do you know?
http://www.amazon.co.uk/Am-Tech-Larg...A3P5ROKL5A1OLE
That kit should do the job yeah?
A regular drill bit will cut the hole in the plastic inlet pipe. There's a grommet that seals the hole. Be sure to get all the chips out of there, then get them out again. Don't want then sucked into the engine.
-- Chuck
-- Chuck
I have an extensive range of drill bits and didn't have anything other than a spade bit or masonry bit big enough, which I didn't want to risk on something to do with my car ! Hence the advisory, if you want to do it with something else, feel free
Does the grommet you mentioned come with the KN FIPK kit?
The kit includes everything needed to include the grommet. The intake works for both engines and there are hoses, caps, and grommets to handle both types. There's a cap over one hose intake of my 2.2 (AP2) intake that's apparently used with the 2.0 (AP1) engine.
All parts and instructions. Takes an hour. Hardest part is mounting the airbox.
-- Chuck
-- Chuck
energetic
Συναντήσεις και εκδηλώσεις
82
12-24-2008 02:58 AM
energetic
10-31-2008 12:31 AM
