OEM clutch
OEM clutch
Hi,
i want to order from USA OEM clutch for replacement.
what are the correct part numbers?
my car is EDM 2007.
i guess i need cover, friction plate, thrust bearing and possibly a flywheel.
many thanks in advance !!!
Gennady
my car is EDM 2007.
Gennady
4 part kit would be ideal:
friction plate, pressure plate, thrust bearing (bearing that goes into flywheel), and release bearing.
flywheel only needs skim/replace if it's overheated and/or juddering.
...oh, i dont have partnumbers, but im sure http://www.hondaoriginalparts.com/ho...p?mod_01=23872 will help (ensure it's set to your s2000 MY)
well, found at some other place:
22100-PCX-005 FLYWHEEL
22200-PCX-055 DISK, FRICTION
22300-PCX-015 DISK, PRESSURE
91006-PCX-008 BEARING, CLUTCH PILOT
22810-PCY-003 BEARING, CLUTCH RELEASE
those should be the same for US AP1s and EDM all years S2000s.
all parts except flywheel are good for US AP2.
silvermonster
05-28-2014 04:03 PM
Orpheus
01-30-2011 01:55 PM
