Perplexing
Old Jul 18, 2007 | 03:55 AM
ukphil78's Avatar
Default Perplexing
I have posted about this before ages ago, but can't find the post.
Went to the Cotswolds this past weekend, and after using the TomTom "Shortest Route" to haul through lots of country roads, I noticed a strange squeak/rattle from the front left of the car (at least thats where it appears to come from).
I have had this noise before - when I went to Wales a while back - but it subsequently disappeared. It squeaks over bumps basically. However, the squeak only appears once you have been driving over bumpy roads for a while.
Does not appear to be steering related - turning wheel etc does not generate it. Speed has not effect, there at high/low speed. I got out and bounced the car up and down by the wheel arch - no noise.
I have also had Chris Franklin do an alignment since I last heard it. He did not spot anything.
Its very odd - and the fact its intermittent makes it a complete f**ker to track down. Any helpful suggestions? I have oiled the bonnet catch already....
Old Jul 18, 2007 | 03:56 AM
ukphil78's Avatar
Hmmm....was giving me an error hence the reposts! Sorry...feel free to delete 3 of them!
Old Jul 18, 2007 | 06:34 AM
MJ2k's Avatar
Rear view mirror?
Apparently there is a screw underneath that can come lose.
Maybe!
Matt
Old Jul 18, 2007 | 09:22 AM
ukphil78's Avatar
I wish.........more coming from passenger side front wheel.....
Old Jul 18, 2007 | 09:30 AM
aldfort's Avatar
Funny stuff is suspension - esp as it has rubber components in it.
sounds daft but if there is nothing wrong try spraying the suspension with Waxoyl. Can't hurt and might make it quieter.
These noises can ofen be caused by slight movement of springs on spring pans or by the rubber bushes flexing.
Old Jul 18, 2007 | 10:18 AM
Phoenix S2k's Avatar
Does it do it with the roof up/ down or both?
I had an annoying squeak where the hood frame contacts the adjustable stop bolt. A small piece of felt applied with double sided tape stopped it.
Old Jul 18, 2007 | 10:41 AM
AquilaEagle's Avatar
Administrator
Was your softop up or down on each occasion?
Old Jul 18, 2007 | 10:42 AM
bilbo's Avatar
Just a thought, and I'm no expert... but it appears that there are mechanical xenon sensors on the passenger side of the car at the front and the back... my rear one is making an annoying noise (I thought the wheel was falling off). Took it to the dealer and they are gonna replace it for a large number of sterling... . To start with the noise was fairly irregular but has got more persistent.... you might be in the early stages of having a problem with the front sensor....
Old Jul 18, 2007 | 11:15 AM
ukphil78's Avatar
Has happened with softtop up and down.
Very clearly related to going over bumps - what I cannot rationalise is how it only seems to happen once the car has been going over numpy(ish) roads for a while. I could take it out for a spin now and nothing.....almost like something warms up and starts to squeak.....
Jhoang
Sep 5, 2015 10:25 PM
Define198
May 18, 2015 11:21 AM
s2kreeper
Jan 17, 2013 11:43 AM
GavB
Mar 15, 2011 12:31 PM
absolute_jdm
Nov 2, 2010 04:49 PM
