Refurbish the Gear Knob
So my 05 S2000, was reasonably low miles when I got it, 42k, now 44k.
Matey who had it for 5-6 years before me, wore rings on his left hand, and the gearknob looks fairly 'worn' as a result.
I've ordered an FN2 Hong Kong gearknob, and while the OEM one is off, I want to refurbish it.
Are there any companies/members who will do this for me, or is it something I can do myself? Is it even possible?
/cue a load of knob jokes
So just to clarify. While your using another nob. You want yours polished? Definitely advise rings off for this job guys and/or gals...
Im sure it is possible to buff up your nob mate.
Good luck.... :-)
Good luck.... :-)
I did my knob with a bit of sand paper (think it was 240 grit ?) take the lacquer off, then used my dual action polishing machine with a medium cut pad and compound. Turned the machine to face upwards and set it going then just held my knob and reseted it on the spinning pad - buffed it up in no time !
http://www.detailingworld.co.uk/foru...d.php?t=280612
Different website but here is my gear knob being sanded with pics
Gary
I can give it a go for you.. I have every grit sand paper imaginable and loads of polishing compounds / wheels.. Plus you're only up the road.
Can't be as hard as my turbo housing was.
Or if you're feeling adventurous we could throw some powder coat over it?
Drop me a PM if you want a hand.
simonprelude
09-20-2011 02:06 PM
