Robs Monster S2K build
#111
Originally Posted by AquilaEagle,Jan 22 2011, 11:31 AM
#112
Originally Posted by rob2.2,Jan 22 2011, 11:21 AM
keep up the good work mate,
that AE86 corolla rocks
if i ever stack the s2k enough to only leave running gear ill be fitting it to a AE86 or mk2 escort
#113
Just opened my email inbox to see AFI in the states have sent me some progress pictures of my custom intake manifold being built. It has some great dyno proven properties for boosted S2K's allowing you to reach the same power levels you could on a stock manifold but with less boost. Anything that lowers the cylinder pressures and delivers the power is good in my book. Now hurry up and ship it!
#115
Hard work mate!
Im using a carbide bit on an air tools attachment initially to smooth out any potential stress points in the casting. Rough sharp edges, casting lines, feeds etc. Then im going over it with and 80 grit flap wheels and cartridge roll. Followed by a wire brush on a bench grinder. It does look well though. It was more of a test than anything. The others will just be smothed on the casting areas and then set for shot blasting. After that I an having them powdercoated slate grey before fitting my polybush kit.
#119
Going to draw up some drive shaft spacers and a bump steer kit. Will get some pictures up once done. Maybe others would be interested in them. If so I'll look into becoming a trader on the site.
