Rust
Old Oct 18, 2004 | 08:14 AM
argep's Avatar
Default Rust
Had a knock on the rear wing 2 years ago. Repaired and looked really good. 12 months ago spotred a couple of rust spots on sprayed wing. Took back and got repaired without any problem. However, another spot has just appeared. Obviously I can take back agained, but I'm getting pretty pi**ed off.
Any advice? I want to keep the car for at least another year!!
Old Oct 18, 2004 | 08:56 AM
euan's Avatar
You wouldn't be the first S driver to have a repair not last very long.
Check the seam weld where the rear wing joins the sill - may see problems there before long
If its any consolation, my folks' R reg E-Class has been back to the dealers about 4 times in 4 years for the same bits to be resprayed again.
Old Oct 18, 2004 | 10:16 AM
AquilaEagle's Avatar
Administrator
Take back again, get money back, go somewhere else to fix it
Old Oct 18, 2004 | 10:36 AM
Beardie's Avatar
Fat chance of that. Probably only a years warranty on the original repair.
I'm led to believe that Honda dealers have had to change to a 3 year warranty on all repairs this year.
Old Oct 18, 2004 | 11:29 AM
gaddafi's Avatar
Banned
If it was done by a Honda approved bodyshop, you should be covered by the full six year anti-corrosion warranty.
Even if it wasn't,, it's clearly a shite job.
Find out which of these they belong to:
MVRA (Motor Vehicle Repairers Association)
VBRA (Vehicle Body Repairers Association)
And use to exert some leverage.
Bandit_287
Jun 25, 2013 06:22 PM
veehexx
Aug 13, 2008 04:18 AM
Bassoctopus
Feb 11, 2005 03:07 AM
sgrant
Aug 28, 2002 08:05 AM
