Rust in the boot, help please.
Old Apr 10, 2012 | 08:28 AM
POG's Avatar
POG
Default Rust in the boot, help please.
Hello all. I have rust on the floor of the boot created by a bad leak. I've bought Kurust to treat it but would like to know if I should remove the black plastic/rubber/leather sheet (in the picture).
Do you think the rust could be forming underneath it?
And, if so, how do I remove it?
Thanks,
Royce
Old Apr 10, 2012 | 09:41 AM
Stoatmaster's Avatar
I had the same problem, but caught it early on.
I had to pull up the sound deadening material at the bottom of the wheel well as it had trapped water underneath it. Yours doesn't look as bad as mine however, I really did have a pool down there.
Once it was rubbed down, treated, primed and sprayed I didn't bother replacing it. I'd advise you remove some small areas to get an idea if the metal underneath is okay. I used a scraper to lift up the edge, it really does peel away in small chunks then.
Old Apr 10, 2012 | 09:45 AM
POG's Avatar
POG
Thanks for the advice.
Old Apr 10, 2012 | 10:44 AM
loftust's Avatar
Find the source of water that is causing the rust.
Leave the boot carpet out and leave your S in the rain for an hour or so, then trace where it's leaking from.
I'd bet it's the rain rail/black trim round the back of the roof/boot vent that is the source of the problem.
You may also need to clear your hood drains...have a look for one of my thread's by searching for 'boot leak'.
HTH
Old Apr 10, 2012 | 10:51 AM
POG's Avatar
POG
HTH
Yea that's the one I read when looking up the problem . I believe it's the same problem. The water does seem to be coming from that area. The hood drains do seem clear, but will give em a clean out too. Thus buying the hardtop has come at a good time, until I can get this fixed.
Old Apr 10, 2012 | 12:16 PM
loftust's Avatar
If your roof moulding is fecked, you can pick one up cheap here on fleabay:
http://www.ebay.co.uk/itm/Honda-S200...6#ht_500wt_969
Mods: This is not me, nor do I have any affiliation with this eBay seller
It's not a difficult part to change once you have removed the interior trim and removed the rain rail from the studs.
Old Apr 10, 2012 | 12:18 PM
loftust's Avatar
Oh, and a new one from Honda is ~ £300
Old Apr 11, 2012 | 03:40 AM
jammer2209's Avatar
Loftust - i'm getting my roof replaced by the chap in Swansea in around a month, and am still on the first roof (12yr old car).
Are there any cheap replacements worth doing - like getting a rain rail/black trim, or the roof moulding for him to whip off and replace. And if they're fine, then maybe get a refund?
1) Are they basic swaps considering he's doing the whole roof anyway?
2) Where's the best place to get a rain rail? Honda/Hendy's?
Any thoughts buddy as you are the guru on the topic? I know my drains are fine, but do get the occasional dribble (expect it to be rain rail having read your post before).
Old Apr 11, 2012 | 03:47 AM
jammer2209's Avatar
POG - i'm no rust expert but in the past i'd wire brush the rush to leave a clean surface then apply some hammerite. And then some waterproof tar-like stuff - loads of it!
Old Apr 11, 2012 | 10:36 AM
RobEvans's Avatar
Mine was the same, i poked it with a screw driver and it made a hole. I removed all the rust top and bottom with a grinder and there wasnt much metal left at all! Haha
rjkoneill
Apr 1, 2016 08:11 AM
andy2000
May 25, 2015 02:30 PM
kmcknight2001uk
Aug 12, 2011 05:06 AM
terry_shum
May 8, 2008 01:21 PM
paullec
Apr 6, 2007 10:16 AM
