Seibon Carbon Fibre Cooling Plate
Old 06-23-2017, 05:31 AM
ITR1649's Avatar
Default Seibon Carbon Fibre Cooling Plate
I have bought a Seibon CF cooling plate but I have some problems fitting it on the car. The holes do not exactly match but I will solve that. A bigger problem is that I'm not able to close the bonnet. Can this cooling plate be used in combination with a K&N FIPK air intake?
Old 06-23-2017, 05:53 AM
noodels's Avatar
May have to cut the bonnet on that side ,best to check where its hitting though.
Old 06-23-2017, 05:58 AM
noodels's Avatar
https://www.s2ki.com/forums/s2000-na...%2A%2A-634401/
one fitted on the link above and looks to be shorter ,so may have to modify the panel
Old 06-23-2017, 06:09 AM
ITR1649's Avatar
Crap... I'm not cutting the bonnet. The Seibon UK description doesn't say anything about cutting so if that's the case they are getting it back. :-)
Old 06-23-2017, 12:41 PM
you reds's Avatar
Hi, have you removed the metal strip underneath the 5 screws on top of the bumper? This should give you enough clearance. I have a similar plate (eBay knockoff!) and an FIPK and mine fits perfectly. It touches the top of the bonnet very slightly but I placed a couple of felt strips on the bonnet so it doesn't scuff the plate too badly. There is also the option of adjusting the bonnet catch to provide additional clearance, although I haven't had to do this. You certainly shouldn't have to cut the bonnet.
Hope this helps.
Good luck.
Old 06-23-2017, 01:09 PM
ITR1649's Avatar
Hi, I have removed the metal strip and re-used the rubber. I'm going to adjust the bonnet catch tomorrow, I hope that will solve the problem. Several people have told me that this combo should fit without any problem so why it doesn't on my '05 is a mystery. :-)
Old 06-23-2017, 01:56 PM
Sipha's Avatar
Sorry I cant help here, but on a totally unrelated note, what is that plate you are covering your front crossmember with ? Looks great.
Old 06-23-2017, 02:07 PM
ITR1649's Avatar
It's a SCW Performance crossmember cover.
http://www.s2carbonworks.com
Old 06-23-2017, 02:20 PM
Sipha's Avatar
Originally Posted by ITR1649
Thanks
chief01
05-29-2015 02:02 PM
TheSnail
For Sale
11-22-2012 07:23 AM
DeeDubya
04-23-2010 07:26 AM
skeithr
04-14-2009 08:35 PM
Quick Reply: Seibon Carbon Fibre Cooling Plate
