Set Up Geometry
Old Feb 20, 2010 | 06:00 AM
slieve_croob's Avatar
Default Set Up Geometry
The front subframe of my 05 S2k (22k miles) has been removed and is now due for refitting.
There appears to be a small amount of lateral tolerance /movement between the mounting bolts and the holes in the subframe itself.
Is there a procedure to align the subframe itself, to make sure it is exactly parallel with the back axle line, all prior to moving on to adjust and configure the front axle geometry via the wishbone adjustors etc. etc.??
Alternatively, is the mounting tolerance of little significance? Or am I being too fussy?
Some early advice would be much appreciated.
Regards & thanks.
Old Feb 20, 2010 | 07:05 AM
Ste_Nova's Avatar
i'd hope there are some alignment holes that you can push pins/bolts threw to get it right
if not make sure all the marks of the bolt heads line up with the bolts
Old Feb 20, 2010 | 03:52 PM
m1bjr's Avatar
[QUOTE=slieve_croob,Feb 20 2010, 04:00 PM] Is there a procedure to align the subframe itself, to make sure it is exactly parallel with the back axle line, all prior to moving on to adjust and configure the front axle geometry via the wishbone adjustors etc. etc.??
Pinchy
21
Jul 3, 2012 04:38 AM
loftust
Nov 23, 2008 12:45 PM
Si2k
Jul 8, 2006 03:27 AM
Rhino80
Mar 3, 2006 03:49 AM
chris_barry
Oct 30, 2003 09:28 PM
