Side Badges
Old Aug 17, 2012 | 07:40 AM
Coldfuse's Avatar
Default Side Badges
Want to do a side debadging this weekend, does anyone here know if they are pinless or not?
Obviously if they have pins at the back then i will leave them as is.
Old Aug 17, 2012 | 07:41 AM
SCZ4's Avatar
No just stuck on, so you'll be fine. Shouldn't leave much residue. Get a hair and gently heat them up, you should be able to pull them off easily.
I'm the opposite, the car came de-badged, didn't like the looks so bought the badges
Old Aug 17, 2012 | 08:02 AM
unclefester's Avatar
Mine were a royal pig to remove, it wasn't the original sticky stuff on the back that's for sure. It took me almost 2 hours per side to get all the badges and all the residue off.
Old Aug 17, 2012 | 10:58 AM
FastFez's Avatar
I did mine a good few years ago , but seem to recall I used dental floss to cut them off by working it behind the badge as it doesn't damage the paint. Once off I think I probably used WD40 clean off the glue residue along with some Meguirs detail cleaner. Then waxed the wing afterwards.
I'm sure there are posts out there that explain it better than i have! :-)
Old Aug 17, 2012 | 11:20 AM
jimmyb1978's Avatar
Save some time and use boiling water to warm them up. They should just pull off with very little resistance, mine did!
Old Aug 19, 2012 | 12:35 AM
Croc's Avatar
i heated mine with the hair drier.
a lot of sticky stuff remianed on the fender - i just rolled it with the dry fingers and it gradually rolled off.
i'm talking about HONDA badges....
Old Aug 19, 2012 | 05:09 PM
Sin_Chase's Avatar
Mine came off easily enough but left loads of sticky stuff on. I just used some tar/grease remover to break down the adhesive then wiped off.
Old Aug 27, 2012 | 06:43 AM
T_W's Avatar
T_W
Looking to refit the badges on mine, did you use a template to position them?
SilverDreamRacer
Feb 1, 2007 10:46 AM
eyeofthetiger
Oct 18, 2005 01:53 PM
SUN
Jul 13, 2002 02:25 PM
cjb80
Aug 11, 2001 11:16 AM
