SRS light on dash help
Old Apr 12, 2009 | 09:33 AM
andy s2k's Avatar
Default SRS light on dash help
ok so i got in the S the other day radio didnt work check fuses it had blown i replaced it and it blew again so i found the source of the problems refitted yet another fuse and my stero works but now my srs light has come check all fuses there fine and the connections has anyone on here got a clue as to get the light of the dash.ps its a jdm import if that helps
Old Apr 12, 2009 | 10:01 AM
loftust's Avatar
There's a 15A fuse under the dash for SRS, check the wiring harness under the dash while you're at it.
The SRS unit itself is behind the stereo, so you may have knocked a connector...blowing the fuse.
Reset the ECU after this, and you should be ok...if not, get the code read, have the DTC reset via ODBII and if necessary let us know what the code is!
HTH
Old Apr 13, 2009 | 03:43 AM
RISLAR's Avatar
Hi Andy, the SRS will not reset from an ECU reset, you will have to use the SRS reset procedure that is in the manual!
Old Apr 13, 2009 | 03:03 PM
andy s2k's Avatar
i havnt got a manual could u tell me how to do it please
Old Apr 13, 2009 | 03:08 PM
m1bjr's Avatar
Its a bit involved mate, get yourself the CDROM "Honda S2000 ESM" and it will always help you out.
eBay or another member
Bibbs
Dec 19, 2007 11:31 PM
s2000 gib
Jul 10, 2006 05:19 AM
cjw07
Jul 6, 2005 07:00 AM
spapdx
May 12, 2003 04:05 PM
Porsche518
Dec 14, 2000 02:19 PM
