thinking of changing the softtop myself
I have done it before on a Triumph spitfire (few years ago to be fair) and did a good job
good idea / bad idea ?
easy / hard ?
any good step by step guides online?
opinions needed please
+ Where to buy from ?
easy / hard ?
I did mine with a Monsoon "OE-like" twillweave https://www.monsooncarhoods.co.uk/ho...0-car-hoods-02 really well made and recommended. I'd do the job again, takes a bit of time to get the centre console/glove box out to get to the roll hoops to free up two bits of plastic that hide the rain gutters - but a totally doable DIY. There is a shortcut you can make by snapping those bits of trim over the rain gutters ( a clean line just where they go under the roll hoop) and I suspect some installers would do that and most people would never notice it's been done
I used this guide https://www.s2ki.com/forums/s2000-ta...ns-top-448840/
i think its covered in the service manual. Unlike Ben i havent grown the Cajonas to do it as it's quite fiddly. Monsoon sell kits i believe or will fit for you, post lockdown. Jack Smiths makes and fits for c£300 which is cheaper than their kit for DIY, hence many head over to him
Spitfire?! I did my MGB roof and won't touch the S2000 roof after watching two complete roof replacements (including mine) and part of another. These were the Robbins roofs. I can't recommend anyone trying this DIY.
The installer used a complete workbench full of tools including multiple drills, rivet guns, and a plethora of hand tools and supplies not normally found around the home. The recommended time estimate is 8 hours and much of the interior needs to come out -- and go back in. A bungled replacement will result in leaks including into the trunk/boot. Not worth the risk for me and if a professional does the job you have recourse if there are problems. The installer had done dozens if not hundreds of roofs.
There are instructions in the Service Manual. Just a glance at the diagrams should frighten all but the most skilled. Starts on page 20-39 of the US manual (the EU version will be identical). <--- that's a link.
-- Chuck
-- Chuck
Previous owner of my car did it himself before I bought it. He is pretty handy with working on his own cars but is not a professional mechanic either. He said it was a pain in the ass mainly due to having to work in tight spaces and fiddle around to get it right, but otherwise he said it went ok. Has never leaked, looks great. If I were doing mine, I would for sure do it myself. But it all depends on how much you want to do it and how much time you have spent working on cars in your life. My father is a mechanic, so I have been wrenching since I was a kid and have never taken my car to a shop except for tires and alignments, so I am more comfortable than someone that has done little more than an oil change for example. So it really depends on your experience and comfort level mostly. The info on how to do it is out there, but it depends on how much you trust your own skills in actually doing the work And if you feel the job is more trouble than its worth to just pay someone else.
There is also the point made above about having some recourse if it goes wrong. That is true. Of course as long as you use a good shop and they do not screw you. Plenty of people have had bad work done at a shop and never gotten it properly taken care of.
I have changed both. The S is a lot more work than the spitfire one. The roof on the S was a Monsoon one and took 2 days but looks perfect. The Spitfire was done in a day and used a lot less tools. Same as the other advice though, followed the thread and took my time.
To summarise; i'd do it again cause i have a shed and would have the time to take a break in between.
