Torque for Android - Video and Data
Old Apr 24, 2012 | 09:34 AM
  #111
davidc1's Avatar
Originally Posted by lovegroova
Update to this - I'm no longer using aLap as it's not being supported, although the free version is still around, so it;s not bad on that front.
Going to use Torque instead, along with my new camcorder which has a lovely wide angle lens.
Torque's Tracker Recorder plug in does work very well too, and if you want an all-in-one solution, that's a good alternative.
I would however thoroughly recommend getting Race Render (and a paid version at that) as it makes the whole video making process so much easier.
I have a gear calculation spreadsheet all worked out too - I'll see if I can get it uploaded to Google Docs.
Thanks for all your efforts!
I have Torque as well, but I don't have a separate camera. Off the top of your head, could you give us a pros/cons comparison or Torque vs aLapHD?
Thanks!
Old Apr 24, 2012 | 09:59 AM
  #112
chrispayze's Avatar
Just playing with Torque myself (although just stationary outside my house currently). It seems to pick everything up well, live. I can't get it to record anything though?!
I've set it to log a few PIDs at 0.25s intervals, press 'start logging', rev it etc to get some values to change, then 'stop logging'. Then I press 'email logs', but the zip fil is empty. Is there another way to export the logs (assuming they're actually there)?
Cheers
Chris
Old Apr 24, 2012 | 10:29 AM
  #113
davidc1's Avatar
I'm also curious if anyone has problems with it connecting to their bluetooth dongle. I bit the bullet and bought a good one...the PIXI one, but sometimes it doesn't connect, and sometimes just takes a long time. Yet, aLapHD would connect with it quickly and immediately every time.
Old Apr 24, 2012 | 10:54 AM
  #114
lovegroova's Avatar
Thanks!
If you get the paid version of Torque, you can use the TrackRecorder plug-in and it'll record video and data at the same time, much like aLap.
The key to making all of this much easier is Race Render (or an alternative).
All you need to do is to record a video file (on the phone or externally) and log a data file. Once you have these two components, it's just a matter of telling RaceRender to use them and then configuring RaceRender to use the correct columns in the data file for your required displays.
Once you've got it all working ok, you can create a template which make subsequent creations really easy.
Cheers
Chris
The log files are stored as .csv files in a directory called "torquelogs" have a look there.
Gear calculations spreadsheet is here: Gear Calculations
Enjoy!
Old May 18, 2012 | 06:14 AM
  #115
lovegroova's Avatar
Just found there's a shift lights plug-in if you have the paid version: https://play.google.com/store/apps/d...lmdExpZ2h0cyJd
or the paid version is here: https://play.google.com/store/apps/d...xpZ2h0c1BybyJd
Old May 18, 2012 | 06:50 AM
  #116
Spies's Avatar
I tried this but I just got an error "Cannot find torque".
Old May 20, 2012 | 11:48 PM
  #117
Croc's Avatar
aLAP is dead?
i recently used it with good results:
http://youtu.be/SICgLgb3MAg
Old May 21, 2012 | 01:11 AM
  #118
lovegroova's Avatar
aLAP is dead?
Well, it still works, but is not being updated or improved any more - If you visit the forum you can see the last time the developer logged in was on March 17. A real pity.
Torque is very good though.
Old May 21, 2012 | 03:38 AM
  #119
Croc's Avatar
yea, too bad.
does torque record sound from external microphone?
Old May 21, 2012 | 04:08 AM
  #120
lovegroova's Avatar
yea, too bad.
Don't think so, you could ask for it to be added in the torque forum, or email the developer here: ian@prowl.org
http://torque-bhp.com/forums
I'm planning to use a proper camcorder and torque log files to do the vids from now on - it's very easy with Racerender.
