Tyre profile
Old 04-03-2011, 10:53 PM
TangoVTEC's Avatar
Default Tyre profile
Go from a 45 profile to a 40 but keeping oem widths?
Old 04-03-2011, 11:08 PM
sound_wave's Avatar
The profile is the height of the tyre, isn't it? If it is, the radius of the tyre will drop, so you're speedometer won't be accurate (unless the speedo compensates automatically).
I think that's why the 17" wheel's tyrewall is an inch narrower than the 16" one.
Old 04-04-2011, 12:25 AM
GavB's Avatar
Assume you mean for the fronts? In which case speedo is not a problem, but it could look bad! Will make your wheels look smaller and your arch gap bigger. Why do you want to do it?
Old 04-04-2011, 01:27 AM
sound_wave's Avatar
I agree with Gav - mis-matching tyres would look garbage. I assume it's just becasue you can get cheaper tyres, right?
Old 04-04-2011, 01:29 AM
TangoVTEC's Avatar
The vredesteins I want only come with a 40 profile, Also the reduced sidewall might let me drop it a little/stop it rubbing.
Old 04-04-2011, 02:25 AM
veehexx's Avatar
http://www.club80-90syncro.co.uk/Syn...calculator.htm
Old 04-04-2011, 07:15 AM
TangoVTEC's Avatar
I did want to get Ultrac Sessantas all round, but they are out of stock of the OEM front size.
Guess a 225 is out of the question too.
No matter, ill find summit else.
Thanks all.
Old 04-04-2011, 07:27 AM
veehexx's Avatar
if it's as simple as 3 is twice as soft as 1.5, then yes. 5% profile change does cost.
ofcourse it might help on steering feel; stiffen up the somewhat soft front end (my goodyear eagle f1's are a touch soft)
speedo out shouldnt make a difference as the speed is taken from the gearbox and thus the rear wheels speed, and not from the front wheels. if you were changing the rolling radius of the driven wheels, then that'd be different. front wheels will just 'keep up' and will have a higher RPM as minor as it is.
your also saving a bit of unsprung mass too, so that'd help aswell
Old 04-04-2011, 07:32 AM
GavB's Avatar
I have 225/45 on mine for more front grip. 225/40 would probably be asking a bit much of the sidewalls though.
Old 04-04-2011, 09:19 AM
Benjamico's Avatar
I've just ordered 245/35/17 for the rears as I wanted to reduce side wall wobble, I'll report back how I get on...
R5HKK
03-12-2018 05:28 AM
Rogc
04-18-2011 06:48 AM
razorsharp192
02-24-2011 12:53 PM
Ant09
12-04-2005 04:21 AM
BSM139
01-27-2005 07:01 AM
Quick Reply: Tyre profile
