Vibrating Sound at around 6k-7k revs
Old 05-19-2007 | 01:13 AM
Mattyboyz's Avatar
Default Vibrating Sound at around 6k-7k revs
I have an annoying vibrating sound coming from the passenger side door just as the fun begins. It sounds like its coming from the speaker. Perhaps its loose screws or something.
Anyone else had and solved this?
How do I get the side panel off to investigate?
Cheers in advance.
Old 05-19-2007 | 02:09 AM
wingnutLP's Avatar
mine has recently started doing this...
If you find a solution let us know
Old 05-19-2007 | 05:55 AM
m1n18oy's Avatar
I've been finding that since putting 18s on accelerrating through 45-55mph in 3rd gear there is vibration coming from the rear but after checking tyre pressures that sorts it out. Its only a matter of about 2psi that causes this!
Old 05-19-2007 | 10:52 AM
Havas's Avatar
I tracked this down to my Window, once you remove the door car at the top of the door there is a spacer to push the window against the rubber, a little adjustment to this and I no longer have door vibrations in pot holes or on VTEC.
Old 05-19-2007 | 02:43 PM
hoppingdeth's Avatar
I get a buzzing at about 4k from my rear view mirror! It
Old 05-20-2007 | 06:51 AM
Mattyboyz's Avatar
Havas,
Not sure I understand your description.
Could you explain in more detail please.
Cheers.
TKim103
01-30-2010 10:17 AM
Shiskine
07-08-2005 03:25 AM
pikkashoe
12-06-2004 10:50 AM
Lotusman
10-04-2002 12:08 AM
Quick Reply: Vibrating Sound at around 6k-7k revs
