what went wrong?
Old Feb 11, 2008 | 10:35 AM
veehexx's Avatar
Default what went wrong?
started car up this morning and left to idle for a few moments to help defrost the screen.
bout 2-3mins later the EPS light comes on. no assistance.
weird. so turn off ignition for a few seconds, and start backup. light still on.
not having time to mess about with it a set off for work. mearly 200yards down the road the lights comes off and EPS re-engages all by itself.
had the car since mid october and it's never come on before. was fine when i left work to come home: no EPS light on, EPS working fine.
was parked the same as it has every day since i bought it (nose down hill, half on kerb), and no leaks apparent last time i checked (xmas)
anyone have a guess at what happened?
Old Feb 11, 2008 | 10:40 AM
motogp1's Avatar
Dont worry mine did a year or so ago, the ecu thinks the car is moving so turns off the eps (electronic power steering) .
ill find the thread
Old Feb 11, 2008 | 10:51 AM
MB's Avatar
MB
Member
If you rev it for too long when stationary it will set off the EPS.
Once you pull awy and turn the wheel, it goes off.
veehexx's Avatar
could be.......... had the throttle part-open to warm it up a bit quicker (about 2-2.5k rpm)
Old Feb 11, 2008 | 10:54 AM
AquilaEagle's Avatar
Administrator
Mine did this when very cold once. Been known to happen. Not an issue AFAIK, unless it always stays on.
Old Feb 11, 2008 | 10:58 AM
motogp1's Avatar
Found it
https://www.s2ki.com/forums/index.php?showtopic=460850
Old Feb 11, 2008 | 12:02 PM
veehexx's Avatar
mind at rest now thanks guys!
atleast it's not something playing up that i have to fix..
Eibmoz75
Oct 15, 2023 04:32 PM
Dembo
Aug 16, 2014 07:03 AM
silvers2k01
Nov 9, 2007 05:45 AM
667
Dec 17, 2006 08:22 PM
gti2000
May 19, 2005 07:07 PM
