Windscreen Changed Then A CEL
Well I finally sussed the problem this weekend.
I reset the CEL and there appeared to be no problems with the speedo failing or a repeat CEL coming back on. I then turned on my A/C and the speedo immediately dropped to zero.
The only thing I could think of which I had done is connect the yellow box into the speedo signal cable in January. Obviously since then I didn't have any use for A/C so the problem has now only come to my attention.
After testing the 12V to the yellow box the negative connection lost its feed whenever the A/C is switched on. I've now connected the negative to the chassis, problem solved.
Thanks everyone for the input.
Andy
Andy
