Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
Leaking?
Old Oct 10, 2009 | 09:42 PM
Zgradis's Avatar
Default Leaking?
Ok so when it rains there is a spot in the passenger side where water sits and when it rains hard it builds up over night, now it will not leak into the car and drain out normally, however when i accelerate after it has built up it will leak into my car... any ideas why this would only be happening when I accelerate? (after i have accelerated for a little bit the water will all come out then it will stop) Any ideas how to fix this?
Thanks for any advice!
Old Oct 11, 2009 | 07:03 AM
Luder94's Avatar
Where on the passenger side? Over the outside shoulder? If so, there's a drain tube there in the convertible top recess. You may just want to check to see if the drain tube is clogged up.
Old Oct 11, 2009 | 09:44 AM
Zgradis's Avatar
Yeah that sounds right, i'll open the top today and check for any clogs, thanks!
Old Oct 11, 2009 | 01:45 PM
Zgradis's Avatar
I checked it today and there was a little filter type thingy, so i pulled it out, now just gota wait and see if that helps, I think it was clogging up the water flow, thanks man!
Old Nov 1, 2009 | 05:19 PM
Zgradis's Avatar
Didn't help i've been reading and the next step sounds like lots of soft top grease...
cthree
S2000 Service Bulletins (TSB)
Mar 10, 2014 08:17 PM
user 192245235243
Jul 24, 2011 11:14 PM
timlee2002
Jul 25, 2009 03:10 PM
ajays2k
Jun 19, 2007 04:02 PM
themush1326
Oct 15, 2005 05:50 AM
