Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
OIL FLUIDS
Old Mar 26, 2013 | 08:51 PM
Elvi s2k's Avatar
Default OIL FLUIDS
So i got the whole week off from work and i wanna work on my car before the dragon
brakes, polishing slave cylinder and grease them
change out transmission fluid, diff fluid and motor oil, filter
here's what i got so far. AMSoil 10W-30 5 BOTTLES and Honda filter from Honda
I don't know what oil i should go for the trans and diff
can anyone help choosing the fluids
One more thing my clutch pedal is hard i looked under where the pedal is and i notice that from where the cylinder fork is
there's oil or grease leaking from it anyone know what could it be?
thanks !
Old Mar 26, 2013 | 09:21 PM
equ117's Avatar
Genuine Honda transmission fluid for the tranny. Some run GM syncromesh friction modified. I know I did because of a notchy gear box. It def man a significant difference in the smoothness of the trans. If all is good with your trans Id stick to the honda fluid. I kinda almost look at the GM syncromesh as a bandaid.
I know a lot of people run Mobile One synthetic 75w-90 in the rear end. I personally did in my stock s2000 for a year. no issues. You can also consider Amsoil gear oil.
All of the fluids I speak of can be found here http://hardtopguy.com/store/home.php?cat=56
The leak you speak of....your clutch master cylinder might be leaking. Pretty notorious on s2k's. Snap a picture and post it up so we can see what your talking about and can verify.
Old Mar 26, 2013 | 10:16 PM
Timbagoo's Avatar
This...
https://www.s2ki.com/s2000/topic/358...-oil-journals/
Old Mar 27, 2013 | 04:31 AM
jeggy's Avatar
The leaking fluid/grease from the cluch rod is very typical. They will leak if you never change your clutch fluid. To prevent it, all that needs to be done is suck out the old fluid from the master and refill with fresh fluid. Do this once a year. Old fluid will eventually leak out from the clutch rod seal. Im seeing this happen more and more as these cars are getting older.
Old Apr 23, 2013 | 06:55 AM
jhkim161's Avatar
Where do you shop for fluids around illinois area?
I just ordered from HTG but would like to avoid the shipping charge in the future.
JohnnyJuan
Mar 4, 2013 04:14 AM
DangerZone9K
Nov 24, 2009 12:21 PM
sweetmeat
Mar 15, 2006 05:44 AM
CosmosMpower
Mar 10, 2006 03:12 PM
ralper
Aug 1, 2004 12:15 PM
