Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
Softtop switch
Old Oct 8, 2005 | 02:11 PM
naseeb's Avatar
Default Softtop switch
I thought the softtop switch would disengage when you install the hardtop and the defroster?
Am I correct? I wanted to make sure so I tried to raise the top and it started to move
Old Oct 8, 2005 | 08:09 PM
ruexp67's Avatar
Dude, you keep answering your own questions.
Time to tighten the loose nut behind the wheel.
Old Oct 9, 2005 | 05:40 AM
naseeb's Avatar
Anyone with a hardtop, can you please answer my question without a smart ass comment
Does the switch disengage or not when the top is on? I want to make sure it's doing what its suppose to and I didn't screw something up.
Old Oct 9, 2005 | 08:09 AM
ruexp67's Avatar
NO IT DOESN"T DISENGAGE
Old Oct 9, 2005 | 09:54 AM
VAD's Avatar
VAD
Hardtop? We don't need no stinking hardtop.....
Old Oct 9, 2005 | 10:14 AM
ruexp67's Avatar
Old Oct 9, 2005 | 06:29 PM
naseeb's Avatar
Thanks Hardtop guy, that's what I thought. I recall it working fine last winter.
Old Oct 10, 2005 | 07:38 AM
Luder94's Avatar
Amul...did you make sure to connect the "defroster" clip form the hardtop onto the wire harness coming from the car on the driver's side?
I'm not sure how the wiring is done, but maybe if you didn't connect the defroster wire harness, then the "push-pin" switch that breaks the circuit on the top-down switch may not be activated.
The push-pin switch is the black "button" on the mounting bracket on the driver's side.
Old Oct 11, 2005 | 05:08 AM
S2000GT's Avatar
Originally Posted by Hardtopguy,Oct 9 2005, 08:36 PM
When the hardtop is on the car, the soft top switch is disabled. If you can move the soft top with the hardtop on, you have a problem.
they dont call him the "hardtopguy" for nothing!
doddg
Sep 3, 2015 04:41 PM
will williams
Jul 4, 2014 07:10 PM
chinkywsk
Jan 9, 2007 03:42 PM
Mannn
Oct 30, 2003 06:24 PM
AlexM
Jan 14, 2002 12:31 PM
