ADR Cyphers
Old Nov 11, 2004 | 08:45 PM
ERnurses2000's Avatar
Default ADR Cyphers
Hello,
My question is three fold.
1. Is an 8.5 inch rim on the front too big?
2. The offsets are +45 all around, is that OK?
3. What size tires should I go with?
Thanks,
Adrian
Old Nov 12, 2004 | 06:49 AM
GChambers's Avatar
Banned
1. Yes
2. No
3. Find wheels that will actually fit then ask for tire sizes.
If you do go with a 8 1/2 in front, you are going to need at least a 9 1/2 or 10 in wheel for the rear to keep the same stagger. The +45 offset on this wide of a wheel will make them stick way out past the fenders. They will rub like hell.
Old Nov 12, 2004 | 02:41 PM
sdiablo's Avatar
1. The approved rim width for a 215/35-18 is 7.0'' to 8.5''
The approved rim width for a 245/40-18 is 8.0'' to 9.5''
2. Least +50 I think.
3. +50 offset 215 front 245 rear will work.. Got answer from search
rubbing? NOt sure
Old Nov 12, 2004 | 04:57 PM
Post
Hey guys, thanks for the info. I appreciate all help in preventing me from depleting my funds for shit I cannot use.
Adrian
Old Nov 13, 2004 | 05:52 AM
GChambers's Avatar
Banned
rubbing? NOt sure
Yep, that is the approved rim width. But, when you get that wide, offsets are CRITICAL! You would need at least a +50, maybe more on the 8.5in fronts and if you went with a 9.5in rear, you would need offsets somewhere near +65 to +70.
Old Nov 15, 2004 | 12:55 PM
sdiablo's Avatar
what if I use staggered tires for 8.5 all round..??
I found set of rims that has +50 offset but all round 8.5 width
and think about staggered tires size
215 or 225 front and
245 or 255 rear
Other question in my mind was
7.5 width rim with 215 tires
8.5 width rim with 215 tires
What makes different? 7.5 to 8.5 rims will change the
actual tires width . I know that 8.5 will stick out more with same offset.
Thanks
Shawn
Old Nov 15, 2004 | 01:55 PM
GChambers's Avatar
Banned
Hmmmm... I don't know.
tallen20
26
May 14, 2008 12:26 PM
s2kdryvr03
Jul 2, 2007 06:02 AM
omgvtec
Jun 10, 2005 03:32 AM
RoaringVtec
Jun 7, 2005 02:56 PM
S9735
Mar 28, 2005 12:24 AM
