Advan RG II Offset/Tire Sizes
Hey guys,
I'm considering buying a set of Advan RG II's in the following sizes:
18x8 45mm / 18x8.5 50mm
Can anyone tell me if those offsets are going to limit my tire size options? I will be runnng the car at autocross.
Originally Posted by KerryF,Jul 10 2007, 10:07 AM
Thanks for the replies gents, that helps.
The car isn't lowered, but I do want to be able to run 245/265.
Unless I just run Rs on my stock 16s...
The front is the toughest because your offset up there is WAY far from optimum if your concern is fitting alot of tire. It will look good, but sacrifice alot on tire size options.
To fit that much tire up front, you need an offset of AT LEAST +50 on the front and even then you probably will have to add camber/roll fenders.
The rear is a bit more flexible if you are not lowered since they dont turn, but you probably need a 8.5 inch wheel with a +55 or a 9 inch wheel with +60 to get away with a 265 rear.
I have a 255 on a 9 inch rear with +55 offset (it never rubs) and it is probably maxed out unless I wanted to get ridiculous with the camber or roll the fenders
OK, well then I guess I will just consider these for my street rims, they sound like they'll work well.
Right now my camber F/R is -1.6/-2.5. I'll just run wider tires on the stock rims, which means I'll need to move to Rs. Because you can't buy good tires wider than about 225 for the 16" rims. I do know people that are running 265 V710s on the stock 16s in the rear.
droptopf22
Aug 31, 2011 06:02 AM
