AP2 alignment specs for tire longevity
Old Feb 19, 2006 | 10:28 PM
TR-S2K's Avatar
spa-zz,
Front toe is zero, you think that I should run with toe out ?
Rear toe-in is 0 degree 20 minutes for each side, total toe-in is 0 degree 40 minutes. How do you translate degrees to inches ?
Old Feb 20, 2006 | 03:59 AM
spa-zz's Avatar
No, zero toe is fine on the front. Toe out will increase wear.
The formula to convert back and forth between degrees to inches is:
[degrees toe] = [inches toe] / [tire diameter] * 180 / pi
But don't worry about that if you don't know how to calculate it out. When you get your alignment, just specify the toe settings in inches.
Old Feb 20, 2006 | 04:33 AM
spa-zz's Avatar
Ok, I created a quick Excel sheet to convert between inches and degrees:
Click here for the Excel file
Old Feb 20, 2006 | 10:49 AM
TR-S2K's Avatar
spa-zz,
For non aggressive driver who wants to have long tire life, what are the specs for AP2 ? Will you fill out missing numbers below. Thanks.
Front:
Caster
Camber
Toe Left
Toe Right
Total Toe-In
Rear:
Camber
Toe Left
Toe Right
Total Toe-In
Old Feb 20, 2006 | 11:02 AM
03_AP1's Avatar
Jesus man!! He's told you a bizzillion times.
Keep the stock honda settings, but reduce the toe in the rear.
Not a hard concept.
I did the same, I'm running 1/16" toe per side for total of 1/8" total toe. That is half of the stock setting and it works fine.
Old Feb 20, 2006 | 02:01 PM
TR-S2K's Avatar
Not a hard concept.
What is the stock Honda settings for AP2 (MY04+)? I could not find it and I'd searched more than 10 times. I found specs for AP1, at least for MY99-MY01, but no specs for AP2
Old Feb 20, 2006 | 02:40 PM
TR-S2K's Avatar
I found Honda alignment specs for MY04, it is on page 181 of owner manual in section Technical Information.
Toe F: 0.0 in, R: 0.15 in
Camber F: -0*30', R: -1*30'
Caster F: 6*
I know what to do now, keep the front as specified but reduce rear toe-in to 0.10 in each side and camber to -1* 00' (-1 degree)
Sorry for not reading owner manual more carefully, and thanks for all inputs.
Old Feb 20, 2006 | 06:17 PM
03_AP1's Avatar
be carefull now.
That .15" rear toe could be TOTAL TOE - meaning .075" per side. In which case going .10" per side is actually MORE than stock toe in.
The AP1 manual says .24" Toe in - meaning .24 TOTAL toe or .12" per side. Not sure if they reduced the toe in on the AP2 for a friendlier setup.
Just might wanna double check.
Old Feb 20, 2006 | 07:12 PM
TR-S2K's Avatar
The 2004 Owner Manual does not say if this is total toe-in or per side. If someone has AP2 Service Manual, please look-up the specs and post the min, norm and max values.
I like to run minimum toe-in for the rear, whatever it is. Thanks
Old May 7, 2008 | 05:07 AM
mickey finn's Avatar
I know it's been two years, but anyone get the answer to this yet?
JSWhaler
Nov 19, 2009 07:13 AM
alexdog1
Feb 17, 2009 06:56 PM
E-Z
Jun 2, 2007 12:57 PM
RazorV3
Nov 14, 2004 08:18 AM
gerryk
Oct 19, 2003 09:46 PM
