AP2v2 Wheel weight
How much do AP2v2 wheels weigh? Well...I was curious too, and since I was selling mine I weighed them before I boxed them up.
Fronts 20.38 lbs
Rears 21.73 lbs
Front
Rear
Other items:
Rear Suspension
Rear upper arm 3.81
Rear lower arm 11.29
Rear tow arm 1.93
Rear Hub+Knuckle 13.34
Brake Caliper + Bracket 7.26
Brake Rotor (new) 10.04
07 Rear Sway Bar 8.66
Front Suspension
Front upper arm 4.45
Front lower arm 10.63
Front Hub+Knuckle 15.29
Steering rack + tie rod ends 34.60
07 Front Sway Bar 9.44
Brake Caliper + Bracket 9.50
Brake Rotor (new) 13.70
Subframe ~ approx 35.00
Engine
OEM Battery 25.00
Stock Intake 10.25
Interior
Passenger Seat 40.70
Driver Seat 33.21
Rear Bulkhead 11.03
Drivers roll hoop 8.23
Passenger roll hoop 8.28
Metal side plate (2) 3.32
Center glovebox 4.76
OE Steering 3.61
OE driver airbag 2.58
Instrument console 2.50
Driver door panel 6.51
Passenger door panel 6.31
Tweeter + crossover 0.86
door sill panel 0.67
Soft Top Tray Lbs
Bottom 2.88
Sides (2) 1.85
Front 0.30
Rear 0.68
Soft Top 56.71
Soft Top Motors (2) 5.25
OEM Hardtop 54.xx
Fronts 20.38 lbs
Rears 21.73 lbs
Front
Rear
Other items:
Rear Suspension
Rear upper arm 3.81
Rear tow arm 1.93
Front Suspension
Engine
OEM Battery 25.00
Stock Intake 10.25
Interior
Driver Seat 33.21
Rear Bulkhead 11.03
OE Steering 3.61
Soft Top Tray Lbs
Bottom 2.88
Sides (2) 1.85
Front 0.30
Rear 0.68
Soft Top 56.71
OEM Hardtop 54.xx
Originally Posted by deepbluejh,Feb 24 2011, 09:05 AM
I don't think the OP's brake dust add 3 lb. What type of scale are you using?
Using a postal scale, good up to 70lbs and accurate to .2oz
I had also read the 17.6 and 20.5 for the rears but knew that they couldn't be that light, they just didn't feel that light. The v1's might be...idk. I've weighed several components with this scale and everything as shown to be accurate, example: the TRM C3 wheels I replaced my stocks with...each of them weighed 18.8 lbs +/- .1 which was just the difference from one wheel to the next.
Strangely on tire racks site they list only the black wheels as 18.8lbs which made no sense to me as to why black paint was .4lbs lighter than silver or dark grey paint. But apparently its an error on their part because the wheels do indeed weigh 18.8 lbs. If it WERE inaccurate it would be saying things were lighter than they really were, and I don't think the stock wheels are even heavier than that.
Here's what I'll do, I weigh a 10lb weight if its within .2 lbs I'd say its good.
