AP2v2 Wheel weight
Originally Posted by wineboy,Feb 24 2011, 01:42 PM
You need to remove the weights used to balance the wheels and make sure the scale is properly calibrated. I know, I'm being picky. Just sayin'...
Any comments unrelated feel free to PM me
OEM brake weight??
would anyone someone anyone know this?
I'm sure aftermarket while being expensive
must be quite a bit lighter!
And I would think it would make just as a profound
effect to unsprung weight as opting for lighter wheels
would make.
would make.
Rear Suspension
Rear upper arm 3.81
Rear lower arm 11.29
Rear tow arm 1.93
Rear Hub+Knuckle 13.34
Brake Caliper + Bracket 7.26
Brake Rotor (new) 10.04
07 Rear Sway Bar 8.66
Front Suspension
Front upper arm 4.45
Front lower arm 10.63
Front Hub+Knuckle 15.29
Steering rack + tie rod ends 34.60
07 Front Sway Bar 9.44
Brake Caliper + Bracket 9.50
Brake Rotor (new) 13.70
Subframe ~ approx 35.00
Engine
OEM Battery 25.00
Stock Intake 10.25
Interior
Passenger Seat 40.70
Driver Seat 33.21
Rear Bulkhead 11.03
Drivers roll hoop 8.23
Passenger roll hoop 8.28
Metal side plate (2) 3.32
Center glovebox 4.76
OE Steering 3.61
OE driver airbag 2.58
Instrument console 2.50
Driver door panel 6.51
Passenger door panel 6.31
Tweeter + crossover 0.86
door sill panel 0.67
Soft Top Tray Lbs
Bottom 2.88
Sides (2) 1.85
Front 0.30
Rear 0.68
Soft Top 56.71
Soft Top Motors (2) 5.25
OEM Hardtop 54.xx
Rear upper arm 3.81
Rear tow arm 1.93
Front Suspension
Engine
OEM Battery 25.00
Stock Intake 10.25
Interior
Driver Seat 33.21
Rear Bulkhead 11.03
OE Steering 3.61
Soft Top Tray Lbs
Bottom 2.88
Sides (2) 1.85
Front 0.30
Rear 0.68
Soft Top 56.71
OEM Hardtop 54.xx
Very nice
can you add that info to your first post. I've already added this to the library and will edit the title since you've added this info.
I'll add weights of the SRC's, KW's, Bilsteins and Öhlins to the library as well.
Maybe I'll title it "Weight Weenies"
j/k
j/k
edited, I pretty much weigh everything I can when I take it off the car. Sadly there isn't too much more I plan to take off for a while. I've been thinking about removing the tar/sound deadening under the seats so I could possibly weigh the carpet too. Also, all of the tar in both the trunk, on top of the rear wheel wells, and the rear decklid (under the soft top tray) totals to ~ 5.25 lbs
OE Steering 3.61
OEM Hardtop 54.xx
OE Steering 3.61
OEM Hardtop 54.xx
passenger seat is not that heavy.
oem steering wheel should be a lot heavier.
oem hardtop should be 45-47lbs.
06+ passenger seat with rails is that heavy...
here is the brake down of the components of the seat, and yes I went that far.
Components
Px Seat back = 13.95
Px Seat bottom = 9.0
Px rail = 17.06 left rail = 8.175 right = 7.8 center = 1.08
Driver Seat back = 14.06
Driver Seat bottom = 8.49
Driver rail = 10.0 left rail = 4.46 right = 5.54
The OEM steering wheel is also that heavy, that is minus the airbag which I listed separately...total weight with both combined is ~ 6lbs.
The hardtop is one thing that would be really hard to fit on that scale
so when I corner weighed the car before and after I had my half cage built we weighed it with and without the hardtop...no other changes. That way I could finally put debate to an end regarding how much it weighs. If I only end that debate for myself thats fine with me. The car with me in it and a practically empty tank of fuel weighed 2827 with the top and 2773 without the top.
Components
