BBS LM 17x8,9
Old Nov 21, 2010 | 07:08 AM
vxn12's Avatar
Default BBS LM 17x8,9
I bought BBS LM wheels and the center rings don't fit over the hub. I don't want to go with spacers. Was wondering if Tirerack or anyone else sell the center ring and center ring retaining clip for the S2000. I don't know the exact sizes for the F&R hub. I could remove the installed ring, but it would not be hub centric. Any ideas or suggestions? Thanks.
Front
Rear
Old Nov 21, 2010 | 01:59 PM
USCG S2K's Avatar
remove the currently installed rings. Our cars have studs so wheels are not hub centric. Hubcentric rings are important when hub is required to keep the wheel on center, since the wheels on our cars are centered on the studs, rings are not needed. hope that helps
Old Nov 22, 2010 | 01:07 PM
Jim@tirerack's Avatar
Former Sponsor
Your car is still hub centric as are all cars. The lugs just hold the wheels on. I have the rings available.
Old Nov 22, 2010 | 03:07 PM
vxn12's Avatar
So what is the purpose of the center ring? I thought that it is important to have and it needs to fit. Forgot to mention that the ring can rotate around the hub. Jim, how much are 4 rings and 4 retaining clips? Are the front and rear rings the same size for S2K? Thanks.
Old Nov 22, 2010 | 08:20 PM
USCG S2K's Avatar
Jim, just curious how can a car be hub centric when its wheels are centered based off the studs and not the hub? i was always under the impression it was on or the other. either the wheel centered itself off the hub (like a BMW) or the studs( like the s2k). I know there is a large number of people in the euro racing community that swich to studs for the specific reason of eliminating wheels due the hub bore being to big ( rings crack when you track a car). Not trying to argue just genuinely curious.
Old Nov 24, 2010 | 11:53 PM
dc5type_S's Avatar
My LM;s have the same rings...only problem is i cant remove those rings
Old Nov 25, 2010 | 06:31 PM
vxn12's Avatar
I used two small flat-head screwdrivers to pry the retaining clip that hold center ring to the wheel. Took a few tries, but it came out. All I need now is the new center ring. Jim, I need 4 center rings, please let me know they cost. Thanks.
Big Nel
Apr 17, 2012 10:21 AM
dc5type_S
Nov 16, 2010 10:57 PM
darkwatch
May 16, 2008 05:52 PM
socal28
May 16, 2002 05:45 AM
SCS2k
May 19, 2001 05:40 PM
