Biggest tires on AP2 with stock 17' rims ?
Old 06-05-2017, 03:07 PM
  #41
DavidNJ's Avatar
Originally Posted by Mike RT4
I think I know what I did LOL .
I definitely went with (H&R) 15mm spacers (as stated), so not sure where you got the 5mm figure from?
To negate boring the wheel, you would need 20mm spacers and a custom 64.1 to 70.1 spacer, but there is not enough meat on a 15mm to do this (I did look into having a rear one bored out before I had the wheels machined, as I wanted the option of being able to rotate the wheels). I felt that 20mm would have been too aggressive and not allow me to track the car (unless I left the ride height stock). This set up has been achieved with zero arch modifications (which is what I wanted) .
How much negative camber did you use? The STR setup is a 17x9 with offset between +60 and +63. The stock rims with a 15mm spacer would be +50, although 12.7mm narrower making them closer to a +54mm on a 17x9. The negative camber is necessary to get them under the fender.
Old 06-05-2017, 08:39 PM
  #42
s2000Junky's Avatar
5mm spacer is all that is required to clear the bigger front hub. Some opt for that, some opt to run no spacer and bore the wheel.
Old 06-06-2017, 09:13 AM
  #43
Mike RT4's Avatar
A fraction over 2 degrees on the front and 2 degrees on the rear
Old 06-06-2017, 09:17 AM
  #44
Mike RT4's Avatar
The reason for the spacers was two-fold - in my research I read that you needed spacers to clear the inner arches, otherwise you had issues on full lock, plus at a later date I will be fitting an AP BBK, which requires these spacers to fit behind the OEM wheels - it only looks good as an aside
Old 06-06-2017, 09:48 AM
  #45
s2000Junky's Avatar
con40
02-13-2013 06:16 AM
npham
12-30-2006 02:22 PM
marsh1665
04-28-2006 05:06 AM
jdnissanz
02-23-2006 09:31 AM
Wisconsin S2k
01-23-2005 04:59 PM
Quick Reply: Biggest tires on AP2 with stock 17' rims ?
