Can i make these work?
Old Feb 22, 2013 | 11:39 AM
PickelJuice's Avatar
Default Can i make these work?
Whats up all, quick question, does anyone know if i will be able to run a 17x9 wheels with a +35mm offset? I heard some people saying we cant run anything less than a 43mm offset.. my car is lowered and odviously will be lower or higher once wheels are mounted on.
Thanks guys! I wanna buy wheels asap but these offsets are killing me lol
Old Feb 22, 2013 | 11:44 AM
Manga_Spawn's Avatar
Site Moderator
You can make them work in the rear but the front will be an issue. You will need a fender roll, tab relo and an alignment to make them fit and make sure you do this BEFORE you put the wheels on. The front will really be your issue for this. I have 17x9 +43 in the front and it is flush with the fender and I had to run 2 degrees of camber.
Old Feb 22, 2013 | 11:57 AM
yea i was planning on rolling the fenders a head of time.. so are you saying that those wheel specs would work in the rear without rolled fenders?
Old Feb 22, 2013 | 12:36 PM
Sileighty's Avatar
You'll have to roll and relocate tab in the rear as well.
Old Feb 22, 2013 | 01:03 PM
Site Moderator
No. They will work IF you roll, relo the tab, and get an alignment for the rear. The front is the part where it won't really fit even with the roll and alignment.
Old Feb 22, 2013 | 01:17 PM
Originally Posted by PickelJuice' timestamp='1361566633' post='22356654
[quote name='Manga_Spawn' timestamp='1361565845' post='22356632']
[/quote]
what does it mean to relocate the tab?
Old Feb 22, 2013 | 01:55 PM
Site Moderator
https://www.s2ki.com/s2000/topic/953...-no-harm-done/
https://www.s2ki.com/s2000/topic/837...tab-relocated/
Old Feb 22, 2013 | 03:59 PM
1nate7's Avatar
The front will work if you run a 225/45 tire.
Old Feb 22, 2013 | 05:04 PM
spitfirecwp's Avatar
Your front will work with out a roll. You should really just do researching before posting do measurements use the Internet for the sites that show you the difference Between different set ups.
Old Feb 22, 2013 | 06:51 PM
Site Moderator
^ Where are you getting your info? A 17x9 +35 will not work without a roll in the front. I have seen people mess up their front fenders with stock wheels and being lowered because the tire caught the fender. If you run that aggressive of an offset you definitely need to roll the fenders. Unless you like having jacked up fenders.
