Different Size Tires (Rears)
Old Apr 24, 2007 | 09:37 AM
S2KrNBRuIn's Avatar
Default Different Size Tires (Rears)
I recently got a flat tire and the tire shop that I go to didn't have the BFG KDW 255/35/18 tire that I needed for my driver side rear, so they ended up loaning me a different tire (Dunlop) 245/40/18 until the new one comes in this weekend. Either way, after the Dunlops got mounted and I drove on them for two days I realized that my car steers to the right every time I accelerate. Is this normal or should I be checking my alignment?
BTW I already had an alignment done two months ago, so whats going on?
Old Apr 24, 2007 | 09:53 AM
Jim@tirerack's Avatar
Former Sponsor
You have a different height and width tire on one side of the car. I would not be suprised and anything that would happen.
Old Apr 24, 2007 | 10:10 AM
S2KrNBRuIn's Avatar
Oh ok...thanks.
Old Apr 25, 2007 | 06:09 PM
BSeriouS's Avatar
thats pretty danger ous actually. But yes, your are veering to the right because of your mismatched tire tread and difference in profile.
Old Apr 25, 2007 | 06:14 PM
silentdancer's Avatar
i would change my diff oil after driving like that.
Old Apr 26, 2007 | 09:25 AM
S2KrNBRuIn's Avatar
Well I haven't driven my car all week. I maybe drove 60-80miles total with that setup. Do you think that I'll really have to change my diff oil?
Old Apr 26, 2007 | 10:21 AM
CaptainMike's Avatar
You might have to change you whole differential. I would only have driven to somaplace safe to keep the car. 60-80 miles you'll probably be OK, but you put a ton of wear on your diff doing that. Depends on how different the rolling diameter of each tire is.
Old Apr 27, 2007 | 04:26 PM
xxjdxx's Avatar
I also noticed this (but the car leans to the left when I accelerate) after changing only my rear passenger side due to a flat. But the tire size and brand is the same. Am I subjecting my diff to extra stress?
Old Apr 27, 2007 | 05:07 PM
It depends on the wear, 11mm of tread depth on one tire and 2mm on the other gives you a whopping 18mm difference in diameter. It's generally advised to replace both rears at the same time if the 'good' tire is worn down past 50%. If that's not the case with yours, your pressures could be off, I can usually detect a 2-3 PSI difference in the rears during acceleration on this car which I have never been able to do on any other car I've owned.
Old Apr 28, 2007 | 09:28 AM
S2k-Takara's Avatar
the difference in tire height in the rear can seriously damage your diff...
zack95
May 31, 2012 03:50 PM
zack95
May 30, 2012 03:00 PM
Kyushin
Oct 6, 2011 01:05 AM
WarrenW
Aug 20, 2011 08:54 PM
JS2k.com
Mar 6, 2007 03:01 PM
