Direzza Z1 Star Specs
Old May 22, 2009 | 05:29 PM
  #41
hellspare's Avatar
Originally Posted by starchland,May 22 2009, 04:48 PM
go with 225/50/16. they dont make the star spec in 245/45/16.
im looknig for a set too
Er I meant I was going to get 225/50/16 fronts and 245/45/16 rears. I've read up the sticky and it says correct sizing for rear is 245 for the ap1, no?
Old May 22, 2009 | 07:56 PM
  #42
starchland's Avatar
well, if you go by that train of thought, it leave out lots of excellent performing 225s...and from what ive read most 225s are not much different foot print wise...if ive understood it correctly.
Old May 23, 2009 | 12:26 PM
  #43
negcamber's Avatar
Originally Posted by Jim@tirerack,May 15 2009, 04:45 PM
We are doing a test next week with the Star spec, RE11, Advan Neova and the Kumho XS. I will post what I find in driving them.
Any update?
Old May 24, 2009 | 12:31 AM
  #44
hellspare's Avatar
I'm not quite sure I understand?
Are you saying 245 doesn't always > 225 in the rear? I've always thought wider = better, hence the reason why so many people try to go wide as possible.
So when most of you guys shop for new tires on stock ap1 rims, you guys look for 205/225?
Old May 24, 2009 | 06:19 AM
  #45
iDomN8U's Avatar
The reason for 245/45/16 is because the Honda Spec Bridgestone S0-2 is wider then all the other manufactures 225/50/16.
Therefore to get a tire from another manufacture you would need a 245/45/16 to get back to what you had before.
225 will give you a smaller size tire
Old May 24, 2009 | 08:09 AM
  #46
starchland's Avatar
I thought it was not that much of a difference? I guess you gotta check manufacters specs. But wider is not always better there is usually a compromise and a sweet spot.
Old May 24, 2009 | 10:14 AM
  #47
hellspare's Avatar
But since star specs don't come in 245/45/16, I'd have to buy a different tire if I want to run that size. Do I compromise much by running 225/50/16 instead?
Old May 24, 2009 | 06:49 PM
  #48
starchland's Avatar
well thats also the thing, by eliminating 50 225/50 you take away lots of great tires
Old May 24, 2009 | 07:15 PM
  #49
EBinVA's Avatar
225/16 Star Specs, RE01Rs, etc tend to measure similar to the stock S-02s.
Old May 25, 2009 | 12:22 PM
  #50
starchland's Avatar
ahh i see you are using my sign
ok good to know...i kinda assumed that but would like to see a pic of the tires mounted on the rear.
