Direzza Z1 Star Specs
i forgot to add the Dunlop Sport Max TT to my previous post, i thought the sport max series was only available in 17" and higher until i looked at the booklet tirerack just sent out last week. i know the DW tire life will be more the the star spec, but as we know, it is difficult to compare tire UTQG ratings across different brands and compare the DW tire life (340) vs Sport Max TT (240) vs star spec (200).
on a side note, i do currently drive 1-2.5 hours for work related meetings sometimes about once or twice every 2 weeks giving a coworker a ride (star spec does have tire growl, but the S2000 is pretty noisy all things considered).
Bought the Dunlop Star Spec z1's for my ap1 wheels, and there is absolutely nothing wrong with them. Very satisfied and will buy again. I recently bought ap2v1 wheels on a thread here and will be buying z1's for them, too.
Will be checking tire rack for the review.
Stiffness of the stock AP1 sizes is absolutely FINE. PLENTY stiff for street and track usage.
I've tracked my S on the stock-sized Star Specs and then on Kumho DOT-R compounds (Victoracer and V700 Ecsta) back-to-back. The R-comps are stiffer, no doubt, but the StarSpecs are quite good in this regard, IMO.
Originally Posted by gospeedgo1,Apr 4 2010, 07:59 AM
better tire wear and tire life is a priority along with grip/handling.
Originally Posted by starchland,Apr 3 2010, 01:37 AM
so because a tire feels flimsy to the touch UNMOUNTED, that equates to poor ride quality?
You can even try the jiggle test. Sit on the ground next to the wheel, grab a spoke and shake violently (put your weight into it). Then let go and watch your S2K jiggle like bowel of jello
Now try the same type of maneuver on the road, jiggling the steering for the same effect, but now with snap oversteer! Granted, the grab and jiggle test doesn't really test the compression of the sidewall, only its flex side to side. The S02s flex side to side too, but they do not compress vertically near as much. Just a useful visualization of whats happening to the sidewall while executing that round-about slalom.I'm not kidding around here people.
Originally Posted by AaronCompNetSys,Apr 1 2010, 09:40 AM
When feeling the sidewall on the non-mounted ones, they are substantially stiffer, as expected. These are 225/40/18, and I expect them to be excellent.
Originally Posted by AaronCompNetSys,Apr 8 2010, 05:33 AM
I am comparing these to S02s, not other tires. The S02s are supernaturally stiff, compared to any tire I or my mechanic has ever seen. The Specs may be the same as any other tire out there, but not S02s.
But even if they *are*, the point is, sidewall compliance isn't an issue with AP1 size StarSpecs. They are more than up to trackdays, autoX, and the hardest street usage imagineable.
If snap oversteer is a concern, more lateral stiffness isn't necessarily always "better", anyway. Some lateral compliance will allow the tire greater transitional grip. Of course excessive compliance would be a problem, but StarSpecs do not exhibit excessive compliance in AP1 sizes on the S2000.
There is trade off when it comes to sidewall stiffness/compliance. With a stiffer sidewall, you might get better "feel" and quicker transition, but you sacrifice forgiveness and warning when at the edge of the grip level.
