Flame suit SECURED! Will my CR Kai combo fit? :)
Old Jun 6, 2008 | 07:46 AM
HybridKOOP's Avatar
Default Flame suit SECURED! Will my CR Kai combo fit? :)
2004 S2000. Figure an inch+ lowered. Willing to run negative camber...
17x8 +47
17x9 +44
I'd like to run as meaty of a tire as possible. Anyone with direct experience here? Will I be able to run this with "light" fender mods... What size tires could I get away with?
Any insight appreciated. The wheel/tire thread is a bit vague. THANK YOU!
- Louis
Old Jun 6, 2008 | 07:54 AM
Terror's Avatar
Your setup will fit will very little modification. Probably just a fender roll on both ends (Probably don't even have to go that far).
And before someone else says it, Search.
Old Jun 6, 2008 | 08:25 AM
Sinji's Avatar
it will work with fender roll. you can do 225-255 tire sizes
Old Jun 6, 2008 | 09:40 AM
HybridKOOP's Avatar
Thanks for the helpful input, I appreciate it! No way of going a wee larger than 255 in the rear you think...?
Old Jun 6, 2008 | 09:59 AM
petawabit's Avatar
my 255's on my work 17x9 +44 were pretty flush. was running -2.5 camber too. I'm sure it can be done, but it may stick out a little
Old Jun 6, 2008 | 10:18 AM
Sinji's Avatar
run more camber and it will work. the 265's usually will buble on a 9 inch wheel. the 255's are more square so better response when turning
Old Jun 6, 2008 | 11:17 AM
HybridKOOP's Avatar
Excellent info. Thanks for being so helpful guys.
Old Jun 6, 2008 | 01:54 PM
dat boi's Avatar
They'll fit with stock fenders Mine was also dropped about an inch. The rears will rub a little, but just the rears.
Old Jun 8, 2008 | 07:37 AM
thewhitepearl's Avatar
^^^excellent what size tires are you running?
Old Jun 8, 2008 | 09:43 AM
dat boi's Avatar
I believe they were 225/45/17 and 255/40/17, I'm sure you can run a little smaller width and not worry about much rubbing.
jake64882
Jan 28, 2013 02:37 PM
GerardoCastillo
May 26, 2012 11:27 PM
LABELKiLLz
Feb 4, 2011 07:30 PM
f00dstamps
Jun 16, 2008 11:50 AM
rsxtaci
Feb 18, 2008 08:34 PM
