HELP! Rubbing Issues on the rear...
Old Jun 5, 2006 | 08:46 AM
overlord's Avatar
Default HELP! Rubbing Issues on the rear...
I recently bought a set of LE37t's FRONT: 18x7.5+48(225/40) BACK: 18x8.5+50(255/35) and I am experiencing rubbing issues on the rear.
I am lowered on Espelir springs and have Koni yellows. It is very annoying because no road is perfectly flat and everytime I go over even the slightest dip, it rubs on both left and right rear.
What is the BEST option for this not to rub? I know I coud:
1. Get the fenders rolled
2. Swap to a skinnier tire (dont really want to because the tires currently mounted have a lot of meat on it)
Are there any other options out there?? Please help, I hate driving the car now...
For people who have this setup, please advice what you have done to eliminate the rubbing.
TIA!
Old Jun 5, 2006 | 09:03 AM
Ubetit's Avatar
I don't think rolled fenders are going to help you all that much. You may have to get an aggressive alignment or raise your car also. My wheels are +50 with 245 tires in the rear. It keeps me from lowering my car.
Old Jun 5, 2006 | 09:41 AM
F355FTS's Avatar
Shouldnt the back be +55
Those are the size tires for SSR GT3 with no rubbing. But their back space is +55
Old Jun 5, 2006 | 10:45 AM
tek336's Avatar
I know how you feel overload I have the same set up and noticed rubbing issues at the front and rear wheels. You can try using goodyear eagle f1 gs-d3 in the same size since they are the narrowest tire in that size.
good luck!
Old Jun 5, 2006 | 11:08 AM
overlord's Avatar
Yep, I noticed rubbing on the front as well on higher speeds when hitting a dip. *sigh*
So rolling the fenders would not help me in this situation? I think I am going that route if it works. Please advice.
Old Jun 5, 2006 | 11:18 AM
Ubetit's Avatar
Everything you do will help, rolling fenders won't solve the problem completely though. You have aggressive offsets, wide tires and you are lowered.
Old Jun 5, 2006 | 11:34 AM
tek336's Avatar
Ubetit is correct, every little bit will help. Would you consider 17" wheels instead since there is a wider range of tire sizes available?
Old Jun 5, 2006 | 01:33 PM
overlord's Avatar
I actually upgraded from 17" to 18". I think I will just get the fender rolled to reduce the rubbing at least and find some other way to reduce it more.
Thanks guys!
Old Jun 6, 2006 | 10:38 AM
Jim@tirerack's Avatar
Former Sponsor
More negative camber will also help. Then when the rear tires wear out go with the 245/35R18 and you should be good to go.
Old Jun 9, 2006 | 03:41 PM
ApexMotorPro's Avatar
i have the same wheels with 215/40/18 fr and 255/35/18 rr. i had to rolled the rear fenders and relocate the bumper tab. -2.5 camber in the rear.
jay
#ir
Oct 23, 2015 09:17 PM
burglrdrift
Feb 22, 2012 04:47 AM
iFRYrICe206
15
Oct 6, 2011 05:27 AM
black02S
Aug 8, 2008 05:12 PM
RuRoUni_SS
Mar 19, 2008 09:33 AM
