Help with winter tire sizing
Hi,
Do yourself a favor and pick up some cheap AP1 rims for $200.(or even less. I've seen some go for $75 on regional forums). You're looking at $50-70 mount and the same to dismount/mount your tires in spring. The wear and possible chipping for those Volks aren't worth the hassle and trouble, much less the money you spend this year and next will make up for the cost of the used set of AP1 rims.
Then mount some snow tires on them (205 and 225).
Good luck.
Good luck.
Originally Posted by E White,Dec 15 2005, 05:44 PM
Jim, if one would run 205/55R16 all around ... is it ok to mount them on the oem rear wheels or should one get an extra set of front oem's and run those all around?
