Help with winter tire sizing
Old Dec 15, 2005 | 04:09 AM
KaMxiKaZe's Avatar
Default Help with winter tire sizing
My knowledge of tire sizing is very limited. I am currently running 16x7 (f) and 16x8
Old Dec 15, 2005 | 08:07 AM
NotoriousGQ's Avatar
For winter, skinnier is better. I would go one size down on the rear...maybe 235 or 225 and go the same size as the front 205s.
Old Dec 15, 2005 | 09:22 AM
Paul S's Avatar
Hi,
Do yourself a favor and pick up some cheap AP1 rims for $200.(or even less. I've seen some go for $75 on regional forums). You're looking at $50-70 mount and the same to dismount/mount your tires in spring. The wear and possible chipping for those Volks aren't worth the hassle and trouble, much less the money you spend this year and next will make up for the cost of the used set of AP1 rims.
Then mount some snow tires on them (205 and 225).
Good luck.
Old Dec 15, 2005 | 09:50 AM
KaMxiKaZe's Avatar
thanks for the input!
Old Dec 15, 2005 | 10:11 AM
Jim@tirerack's Avatar
Former Sponsor
You should be in the 205/55R16 front and 225/50R16 rear. If you live in an area that gets a lot of snow you can even run the 205/55R16 all the way around.
If I can help let me know.
Old Dec 15, 2005 | 01:44 PM
E White's Avatar
Jim, if one would run 205/55R16 all around ... is it ok to mount them on the oem rear wheels or should one get an extra set of front oem's and run those all around?
Old Dec 19, 2005 | 05:33 AM
E White's Avatar
..... Jim ?
Old Dec 19, 2005 | 01:26 PM
You'll be fine to mount them on the rear oem wheels since the rear is not that wide and wont be stretching to fit 205/55R16
Old Dec 21, 2005 | 01:06 PM
Former Sponsor
Sorry, You will be fine. The 205/55R16 will actually be better in the snow. If I can help let me know.
sang
Oct 4, 2011 06:14 PM
JDx
Dec 7, 2008 10:19 AM
shox
Dec 18, 2006 12:30 PM
dombey
Aug 13, 2006 06:03 AM
johnqt3
Oct 3, 2005 08:00 AM
