New fuzion problems, help!
Former Sponsor
Hi promking, Everybody is correct. If you give the tires a little time they will be better. They are not going to be as good as the S02 in the dry but I would say better in the wet. They should also give you a little longer tread life. The S03 is going to be substantially better in handling both wet and dry than the Fuzion. It is also better in the wet than the S02.
If money is not the concern the S02 is the best I have seen on the car for performance driving. If I can help let me know.
also did you get the right sizes for these tires? You would need to be running 225's up front and 245's in the back to get about the same contact patch as the S02's.
Administrator
I did the same thing... accidentally peeled out pulling out of the tire place. I figured it was because it was chilly outside and the tires were cold, too. The Fuzions did great on my road trip last month! I say give 'em a chance.
I thought that the fronts were fine at 205, and it was only the rears that needed to be 245.
can someone confirm this?
This applies to I think all tires, if you're not running OEM S02's and you are running the same 205 and 225 stance you are running a thinner tire, so everytime you buy another tire besides a S02 to match or do better you should run 225's in front and 245's in the back.
It's strange because almost all of the other manufacturer's 205/55R16s are really close to the stock size. Normally, only the rear size needs to be upsized.
I wonder if its a typo on the Tirerack website?
