Quick Help, About to purchase tire replacements.
Old Jul 28, 2006 | 10:23 AM
Insert Name's Avatar
Default Quick Help, About to purchase tire replacements.
Ok well I purchased a new set of s-03's for my s2k a while back, the rears are shot but the fronts are still roadworthy. Im going to be putting a set of Bridgestone RE050A Pole Positions on to replace the rears and keep the current s-03's up front. Have a couple questions.
1) Is it safe to mix n' match tires (diff set up front/back) even if they are the same brand.
2) What is the widest tire I can fit on the stock wheels in order to increase the contact patch with the ground. (Stock car, not lowered, etc). I was thinking upping it to 235's or maybe even 245's? Any suggestions?
Any help from Jim would be appreciated, or anyone else who has any reliable info before I blow $300 bucks.
Old Jul 28, 2006 | 10:39 AM
xviper's Avatar
Mixing tires will slightly change the handling dynamics of the car. "Safe" is if you understand this and don't exceed the new limits.
A 245 rear tire is about as wide as you can go with the OEM rims. An aftermarket 245 will give you about the same contact patch as the OEM 225s. Look here:
https://www.s2ki.com/forums/showthread.php?threadid=48572
If you've been running 225 SO3 tires on the back, you've been short changed.
Old Jul 28, 2006 | 11:07 AM
So you are saying step it up to 245's on the rear when i buy these?
Old Jul 28, 2006 | 11:15 AM
xviper's Avatar
Yes, you actually should have had this size on your current SO3s.
Old Jul 28, 2006 | 11:19 AM
Well seeing as tirerack dosent stock s03's or the RE050A, in 245's, im kinda screwed. Time to call Jim
Old Jul 31, 2006 | 07:29 AM
Jim@tirerack's Avatar
Former Sponsor
I do have the S03's back in stock in the 245/45R16. Call me.
Old Jul 31, 2006 | 10:28 AM
Thanks Jim, I did call you and placed my order on Sat....also spoke to you thismorning
xxlap1xx
Sep 13, 2007 05:38 PM
jdm_rsx
Aug 9, 2006 09:19 PM
jmc1971
Mar 19, 2004 07:10 AM
cashout
Nov 5, 2003 03:29 AM
KryptoniK
Apr 25, 2002 06:34 PM
