somebody please clear the issue of wheel offset ?
Old Feb 10, 2005 | 09:54 PM
alexo49's Avatar
+65 for the rear!!
Why are aftermarket S2000 wheel sizes coming with +50-55 offsets?
Old Feb 10, 2005 | 10:53 PM
New Concept's Avatar
Banned
thanx batbite, that was a good explanation.
now answer this, can a wheels offset be customized from 45mm to lets say 65mm by a shop (not by manufacturer)?
Old Feb 10, 2005 | 10:56 PM
RT's Avatar
RT
I think some of what is confusing to NewCon is that the same offset can be achieved with varying spoke clearances to the brake caliper. You can have a wheel with a very deep dish lip and lower caliper clearance or a wheel with zero lip y mucho brake clearance while both having the same offset.
Offset implies nothing explicitly about the depth of the dish (although you can guess the general trend based on any given offset and width)
Old Feb 10, 2005 | 11:22 PM
RT's Avatar
RT
Originally Posted by Nick Graves' date='Feb 10 2005, 08:47 AM
I am always utterly amazed that the effect of changing offset on steering geometry is ALWAYS ignored, and this car is supposed to be bought for its handling!
If the offset is reduced (so the wheel now sticks out of the wheel well more) this can overload the wheelbearings and produce unpleasant steering kickback. In the event of tyre failure, it increases the wrenching on the steering as it increses the leverage. VW used to go for a heavy offset so that their cars had more straight-line stability in such a case or in slippery conditions.
I guess for many people, cosmetic is everything and handling/ride/longevity mattes not a jot.
The intersection point of the Kingpin Inclination Axis and the tire contact patch is the specific effect you're referring to. I agree w/ you 100% that this spec should not be ignored when deciding to change offsets. However, I believe the S2000's high offset design requirements are different than those of the "Front Wheel Drive" high offset requirements that I think you are referring to (mid 70's water cooled VW's). The S2000 uses the high offset wheels to get longer control arms as a means of reducing geometry changes through the stroke of the suspension travel as opposed to the feeble attempt of centering the load on POS under-sized bearings that weren't designed to handle the thrust/bending loads on those Front Wheel Drive units (although the S2000 rear does use those POS bearings, at least Honda stacked two together to reduce the bending load).
All that being said, my after-market front wheels are the same as stock (as Honda designed it ) Why chance changing the intersection point of the Kingpin Inclination Axis if you are not expecting some sort of Gain to offset the Risk of fu<king something up is the way I approach the subject
Old Feb 10, 2005 | 11:24 PM
RT's Avatar
RT
no, you'll machine off your lug nut seats (or at least make them real damn thin )
Old Feb 11, 2005 | 06:48 PM
Warren J. Dew's Avatar
Honda did take the trouble to make sure the wheels were perfectly centered on the king pin axis. I think this does have to do with thrust loads, at least: the centering means that normal drag on the front wheels does not tend to turn them either outward (as would happen with wheels with less offset) or inward. While the load on one side of the car is normally balanced by the load on the other side even with other offsets, the lack of such loads may contribute to the sharpness of the S2000's steering; also, it means that the steering will not tend to pull one way or the other when one goes over a bump with only one of the front wheels.
Old Feb 11, 2005 | 09:05 PM
ILUVMYS2k's Avatar
So would I have any problems with a 18x7.5 wheel with a +45 offset?
Feezy
Dec 6, 2013 11:15 AM
cannonball
Feb 20, 2009 07:47 AM
freq
May 16, 2005 02:50 PM
JspecVtec
Feb 6, 2005 05:25 AM
Team Hybrid
Jan 10, 2002 12:08 AM
