Spacers on stock wheels
You will be reducing the effective offset by adding the spacers. Google "offset and scrub radius" for some good info. For instance,
http://www.subaruforester.org/vbulletin/f7...1609/#post14822
http://www.miata.net/garage/offset.htm
Originally Posted by thebatman,Jun 10 2008, 10:30 PM
I'm getting a headache from all the tech talks =)...I just want my stock rims to look nice without drastically altering handling for the worst.
Originally Posted by SoCalAp2,Jun 10 2008, 10:56 PM
sorry a little off topic, but is somewhat related.
i just bought a set of H&R 5mm spacer to use my OEM rims in the front with Rcompounds to clear my BBK, after i put them on, i noticed that the wheel is no longer resting on the HUB, so basically the rim is resting on the 5 bolts and hold it in place???
is it safe if i track my car like that?
And I think if you have to ask if it's safe for tracking, there's a good chance that it might not be.
If the wheels are meant to be centered by the hub (hub-centric), then there is no guarantee that they will be centered when only using lugs in this case (especially with stock hubs). So there might be high-speed vibration. Generally, it takes higher tolerances (both at the hub/lug and wheels) to get a good lug-centric mount that is smooth at high speeds.
These issues must come up all the time here, right? I know they did on the Subaru forums I used to frequent. I am amazed at how many aftermarket parts, like wheels and spacers, are sold with iffy features (like fundmental hub/lug incompatibility). Best to talk to someone who has done this on their S2K, who is experienced enough to know their stuff, and has thoroughly tested it. I am seeing a lot of possible red flags here...
Bottom line, there is a pretty good reason why the stock hubs have a machined centering lip, and why the stock wheels have a machined centering cone.
Originally Posted by SoCalAp2,Jun 11 2008, 10:03 AM
yes, but the center hub still stays the same even if i change out the bolts...thats the part i am worrying since the wheel is not sitting on the center hub anymore.
I don't know if anyone makes extended centering rings in 5mm. I remember some people had issues with there not being enough hub for their rims to sit on with 5mm spacers. Not sure what they did to fix it though.
Originally Posted by j0nathanl3e,Jun 10 2008, 10:15 AM
If you plan on getting spacers you should definitely get realigned as it will most likely throw out your alignment. Any changes you make to your car's suspension, be it tires, wheels, springs, coilovers, arms, etc. you should definitely get it realigned.
The spacers pictured above are the correct way to do it. Or you need extended studs so that there is enough thread engagement to ensure adequate preload on the wheel when torquing it down.
Also, you don't need to have the centering ring. It makes it easier to mount, but if you properly torque your lugs, no weight is taken by the centering ring, it's all carried by the shear in the friction between the wheel and hub face.
Adding spacers will mess with your scrub radius, it will pull more during braking or over uneven surfaces, but nothing major. It will also increase your track slightly, which will decrease weight transfer and increase cornering capability. It will also put higher loads in to your wheel bearings, so you may see premature wear, but nothing major, they will last 10 years instead of 15 or so if my guess.
as long as the car is not tracked or raced on, the spacers would work fine for the street. 5mm is the maximum size i would recommend on a stock stud. if the spacers come with their own studs then that would be ok to use. just make sure that the spacer and the wheels are torqued down properly in a proper sequence.
