Square 235/40/18 setup?
With the cost of tires, there is no point in moving to a big 18" on this car unless you are going to exceed a 255/10" combination. The benefit of an 18” is the wider wheel and tire options. If your not going to take advantage of that, and alternatively going to the other extreme of conservative 8” widths. It just doesn’t make a lot of sense, and from a looks standpoint, it makes the car look like its on skinny stilts, so who cares what the face design is at that point.
Originally Posted by 1nate7' timestamp='1432165686' post='23619834
[quote name='coop3422' timestamp='1432164250' post='23619805']
Curious why you would pass on them? Because they're not staggered?
Thanks
Thanks
That said, I'd like to stay away from fender work if possible. What kind of work would the front take with a +48 and 235's? Fender roll, pull, camber?
Thanks, sounds like these may not be the way to go.
[/quote]
Definately a roll for the fronts. Rear should be ok but yeah I will echo the not running 8 inch wide wheels in the rear. Kinda pointless.
Hey all, there's also a setup available that's 18x8 +48 And 18x9 +55. This would be ideal, but I guess I'd still be stuck having to get the fenders rolled. Would I have to do anything in the rear, bumper tab, roll, camber, etc. , or would they be fine with that offset? I'd still be planning on running my 235s till next spring.
So I'd need to get the camber done and that's it? How much does that usually cost, is it just the price of an alignment? If I went this route I'd get a 225/255 setup next spring, just too much going on right now.
I'll lightly never let it, the roads are too bad here.
Thanks
Thanks
Thanks
Thanks
235 on an 8+48 would more than likely require a roll. 225 barely fit. You might be able go get away with it if you 2-3 degrees of negative camber. I wouldn't risk it or go through the hassle of rolling fenders to use those tire. Get proper tires and save yourself the headache. Rolled fenders lower resale value, can damage paint and will look out of place if you run a 225 after that.
DangerZone9K
May 27, 2012 06:01 AM
