Tire set up
Old Aug 2, 2006 | 08:57 AM
CBSubliminal's Avatar
Default Tire set up
I need some opinions on my tire set up. I bought my s2000 used. The tire set up on the car were mismatched ,they never had the oem tires on the car. I was running>
205/55/16 Yokohama Avid v4s 2 front
225/50/16 BF Goodrich G Force T/A KDW's 2 rear.
I decided to change the two rear tires because the tred was going low on both rear tires. I changed the tires to 225/50/16 Bridgestone Potenza re750's today. I didnt change the front tires because they still have 80% tred on the fronts. Is this set up acceptable? I know that there are alot of posters stating not to mis match the tires. Need some opinions. Thanks in advance.
Old Aug 2, 2006 | 09:45 AM
xviper's Avatar
You're shy a little rubber on the rears.
https://www.s2ki.com/forums/index.php?showtopic=48572
Old Aug 2, 2006 | 10:19 AM
Eh, so will this effect my tred life on the rear tires?
Old Aug 2, 2006 | 11:17 AM
xviper's Avatar
Not really, but it will affect the car's balance and handling.
Old Aug 2, 2006 | 01:18 PM
I should have read the sticky on the top section on this section of the message board. The car is my daily driver and i take the car to redline sometimes, but dont take corners hard. Will i be safe to ride on the rears till they wear? I really cant afford to buy a new set of rears right now since i just purchased these new tires.
Old Aug 2, 2006 | 02:22 PM
xviper's Avatar
Of course you can. Lots of people do. Just understand what a little less rubber on the back will do. It'll have a tendency to grip less in the rear so just don't get as close to the car's limits as before.
Old Aug 2, 2006 | 02:29 PM
Thanks for your input xviper. I appreciate that.
cbrguy7
Apr 20, 2008 08:10 PM
CyberCJP
Jul 3, 2006 07:43 PM
KLN
Nov 21, 2004 12:56 AM
SSS2k
Mar 8, 2004 02:26 PM
cashout
Nov 5, 2003 03:29 AM
