Tire size for 17x9 +45 with no fender work?
Old 04-30-2014, 08:46 PM
s200082's Avatar
Default Tire size for 17x9 +45 with no fender work?
Need help with tire size for 17x9 +45 wheel, thinking about 245 40 17 or 255 all around, dont want roll or modify fenders any suggestions???
Old 04-30-2014, 10:55 PM
s2000Junky's Avatar
You could do a 245 in the back with good amount of camber -2.5 range. A 225 would be the narrowest tire you would want to mate with a 9" and that package would still be too aggressive for the front without rolling. Either roll the fenders up front or go with the 8 +45. And a 215.
Old 04-30-2014, 10:58 PM
EricJT7's Avatar
My suggestion would be to have the fenders rolled before they are damaged. Better safe than sorry.
Generally, I don't believe a 17x9+45 will fit up front without a fender roll, especially with a 245 or 255 width tire. Even at stock height.
https://www.s2ki.com/...-fitment-guide/
Edit: Yep, what Junky said.
Old 05-01-2014, 09:18 AM
Sileighty's Avatar
^ 245 will fit up front if you're at stock height. I'm running 245 around on 17x9+45 on stock height without any rubbing.
Old 05-01-2014, 09:36 AM
Site Moderator
Manga_Spawn's Avatar
The rear can have a 245 or 255. Fronts should be rolled even at stock hieght. That is a much more aggressive wheel than OEM in front and it could cause problems. There is still enough flex in the suspension that it could contact the fender when turned and with that much more aggressive of a wheel it is much more likely.
Old 05-01-2014, 04:27 PM
s200082's Avatar
ok so roll fronts for sure, how bout rears?? Do they have to be rolled? im dropped on coilovers theres about two finger gap between wheel and fender
Old 05-01-2014, 04:44 PM
gptoyz's Avatar
what kind of tires are you running on this setup?
what are you going for...Track performance….Daily Driving….Hella flush, hella tucked?
what are you current alignment settings?
In my experience on an 05 ap2 with oem and KW clubsport coil overs + track alignment (-2.4 camber) + 255 Direzza Star Spec z1 or 255 Hankook RS3, the rear fender definitely needs to be rolled and tab relocated. This was for a car that was to be driven on the track. However, even when daily driven on our NorCal 3rd world freeway system, if you hit a big enough dip/imperfection it would rub
Same care with a 17x8 +45 225 Direzza z1 or 225 hankook rs3, same problem, rubbing everywhere, actually in one instance driving up a mountain of an incline into a shopping center it even pulled out the front right fender slightly.
My advice, don't do it, but if you are:
Camber Joints (SPC to pull the top control arm in)
Alignment for maximum camber
slight fender roll up front
relocate the tab and slight fender roll in the rear
Old 05-01-2014, 09:31 PM
Site Moderator
if you are lowered you need to roll all of them and relo the tabs. Rears should be ok with near oem camber but front will need more.
Old 05-02-2014, 02:40 PM
s200082's Avatar
car is street driven, no tracking, alignment is oem spec i believe, looking at ad08 tires, thanks for the replies!
Old 05-02-2014, 03:44 PM
gptoyz's Avatar
Extreme performance tires like your ad08r are generally wider than their max or ultra high performance tire counterparts
Sent from my iPhone using Tapatalk
Silvers2kdaily
06-17-2015 09:13 PM
Seanix
01-10-2013 09:39 AM
krnprydeazn
03-27-2012 07:09 PM
shoes59
01-09-2010 11:57 AM
Ouhei
08-05-2007 09:16 AM
Quick Reply: Tire size for 17x9 +45 with no fender work?
