Tire Wear Question
Old 08-15-2017, 06:28 AM
cdt540's Avatar
Default Tire Wear Question
I am a new owner, had my '02 for about six months. The PO installed SSR 18's with Falken 255/35 on the rear and 225/40 on the front. My understanding is the car was the PO's daily driver (113,000 miles) and never tracked. Other than the wheels the car is stock. I recently replaced the tires and the rears were much more worn than the front and the rears were wearing significantly more on the inside half of the tire. Is this normal or do I have an issue? Thanks for any feedback....
Chris
Old 08-15-2017, 08:05 AM
hoobastnk90's Avatar
just get an alignment, all people can do on here is speculate.
Old 08-17-2017, 03:02 AM
rpg51's Avatar
I agree, get an alignment. Also, be aware these cars typically use up rear tires twice as fast as fronts even with a good alignment.
Old 08-17-2017, 05:01 AM
ZDan's Avatar
Don't "just get an alignment". Alignment specs for a car are a VERY broad range. And for the AP1 S2000, even the low end of the specified range of rear toe-in is IMO too much, and the max is way too much, which is why these cars wear the rears twice as fast as fronts. You could have 1/4" or 0.67° of total rear toe-in and be "within spec", and rear tires will wear at an absurd rate. And handling will suck. Minimize rear toe-in and rear tire life will improve.
My generic alignment advice for street cars, within factory specs, is to maximize negative camber front and rear, with front and rear toe as near to zero as spec allows.
For street AP1 , I would recommend something like:
-1° to -1.5° front camber
0.0° front toe
-1.5° to -2° rear camber
0.2° total rear toe (this is less than factory minimum spec of 0.33° total)
CMK (09-14-2017)
Old 08-17-2017, 06:20 AM
cdt540's Avatar
Thanks for input. Now I just need to find a reputable alignment shop in Austin.
Chris
Old 08-17-2017, 06:30 AM
CMK
CMK's Avatar
0.0° front toe
What would you recommend for a car on Eibach Pro-Kit springs? (~.75" lowered)
Old 08-17-2017, 07:24 AM
ZDan's Avatar
For street? Same as above ^^^
Old 08-17-2017, 07:31 AM
CMK
CMK's Avatar
For street, yes. Awesome. Thanks!
Old 08-17-2017, 09:10 AM
Site Moderator
Manga_Spawn's Avatar
The rears always wear faster than the fronts in my experience on the S. The wear is due to the alignment and Zdan already covered that.
Old 08-17-2017, 03:40 PM
Bruunz's Avatar
0.0° front toe
100% Agree - i was on this and now run even more camber on chunky UHP 255s. My tire wear is incredibly even.
Crackerballer
05-05-2010 10:21 AM
Bronxbomber9009
05-07-2009 01:25 PM
oldtrlrnr
05-08-2008 08:39 AM
trendy26
South Florida
11-15-2004 10:15 AM
1Y2KS2K
06-06-2001 03:58 PM
Quick Reply: Tire Wear Question
