Tires rubbing
Old Apr 24, 2008 | 04:24 AM
s2ksmith's Avatar
Default Tires rubbing
Can anyone suggest what i should do, i bought my car already lowered and had the stock 16 rims on the car now i put 17 inches and when i go over bumps u hear the tires scraping the wheel well, is it better to get the wheel wells shaved or see if the shocks are adjustable. Will it be an expensive project? Should i have a regular mechanic look at it or bring it to an aftermarket place that installs rims. When i ordered my rims it came mounted and balanced with tires on in mail. Thanks for any input.
Old Apr 24, 2008 | 06:30 AM
S~Factor Jr.'s Avatar
Well on my dads car we have a 17'' rim with 235 front and 275 rear. Now since our rear is 275 we have been rubbing alot (and sometimes in the front). All we did was roll the fenders, the old fasion way. All you need is a metal baseball bat, a heat gun/hair dryer, and a jack. Lift your car high enough so that you can just fit the bat into the gap between the fender and the tire. Lower the car just alittle bit so there is pressure on the bat. Angle the bat upward about 40degrees. Now use the heat gun/hair dryer and move it side to side along the part that you are rolling (so the paint wont chip). Now just have the bat angled and then start twisting the bat.
I hope that helped i am not very good at explaining things
Old Apr 24, 2008 | 08:26 AM
Jim@tirerack's Avatar
Former Sponsor
You can start with running more negative camber. What size tires are you running on the wheels?
Old Apr 24, 2008 | 09:08 AM
s2ksmith's Avatar
wow that seems like a lot of work....im not the best doing my own thing so i rather have someone professional.....the tire sizes are 245/40R 17 and 225/45R 17
Old Apr 24, 2008 | 01:31 PM
AP2's Avatar
AP2
you put OEM 17" wheels or are they aftermarket?
Old Apr 24, 2008 | 04:17 PM
Spectre48's Avatar
They must be aftermarket. The stocks won't rub when lowered on those size tires.
Old Apr 24, 2008 | 05:41 PM
s2ksmith's Avatar
yea they are aftermarket got rims from discount tire direct rims are drags and the tires are hankook ventus i think the problem is the width of the tires. Im gonna try to shave the wheel wells.
Old Apr 24, 2008 | 11:42 PM
AP2's Avatar
AP2
the problem is more likely the offset
Old Apr 25, 2008 | 07:31 AM
S2K 4 ME's Avatar
The width of the tires is fine, its the offset of the rims thats the problem. You can start by running more neg camber (as previously posted) and if that doesnt take care of it, let the fender rolling begin!!!
I'm running 225/40/18, 285/30/18
S2Kyello
May 24, 2011 02:08 PM
RaceyR6
May 27, 2009 07:20 PM
F20cftw
May 8, 2008 06:45 AM
RedHonda703
Dec 27, 2003 08:24 PM
jackson1628
Sep 4, 2003 08:29 PM
