V rated or W rated???
Old Jul 2, 2002 | 04:50 AM
S2KandTA's Avatar
Default V rated or W rated???
Time for some new tires! after only 12k! The V rated is cheaper but how much of a difference will a W rated tire make performance wise?
Old Jul 5, 2002 | 02:56 AM
CoralDoc's Avatar
That's pretty normal life for the OEM tire, particularly the rears. There are many variables to tire design and their specifications, so the following is an oversimplification of a complex set of relationships. In general, tires with higher speed ratings are more expensive, offer greater grip and have less treadlife than tires with lower speed ratings. Your choice of tires should be made based on your needs and goals. If cost is an important consideration, recognize that less expensive tires will offer less performance but may last longer than the OEM tire. Also be aware that going with a different tire may alter the handling balance of the car. The OEM tire has come down in price over the past year, so is a very good performance value now compared to lesser tires at the same price point ... as long as you don't mind their shorter life .
timdonna1
Mar 4, 2009 08:47 AM
stickercutting
Feb 4, 2008 01:52 PM
MrXpSyChO
Jun 23, 2004 08:02 AM
GVFlyer
Sep 9, 2003 09:37 AM
Notion
Mar 29, 2002 09:18 AM
