V1 AP2 wheels on AP1
Old Aug 3, 2014 | 05:34 PM
ZDan's Avatar
Hard to tell from the pic, but if the tire is only about the same width as the wheel at the lip, they've gotta be 8.5" wheels. If the tire is "pooched" and noticeably wider than the wheel at the lip, then they might be 7". If I had to guess from the pic, I'd say they're likely 8.5".
Old Aug 3, 2014 | 05:40 PM
plizzat's Avatar
Ya they are all about the same width of the rim. No pooching. Would it affect steering a lot, acceleration? Do you need to shave the hubs?
Old Nov 18, 2014 | 03:53 PM
plizzat's Avatar
what if all four are bored out to 70mm? Would the rears be able to fit?
Old Nov 18, 2014 | 07:16 PM
Manga_Spawn's Avatar
Site Moderator
Good Lord what is even happening here? Ok tire size is very wrong. Click the wheel fitment sticky it has all the stock specs.
What were these on? An s2000? If they were and they are all 8.5 he either had 2 of them bored out (very easy just measure them) or he ran a 5mm spacer on the front. Either way they will be fine with correct size tires.
Old Nov 19, 2014 | 11:57 AM
s2000Junky's Avatar
Yep, easiest thing to do is just run the 5mm spacer up front, this allows it to clear the center bore differences and still provide enough threads on the studs to be safe. This is a common alternative to modifying the wheel bore. If it’s going on a basically stock suspended ap1, i would run a 225/45 -255/40 stagger for best traction bias/handling.
s2kdriver80
Sep 3, 2018 05:54 AM
nrcarone
May 18, 2014 01:21 PM
Lucky-R
Apr 19, 2012 10:18 AM
Trent06
Feb 3, 2010 10:58 AM
e3opian
Jan 5, 2009 05:40 PM
