What fender modification will be needed...
Old Jan 21, 2011 | 03:16 PM
bballplaya210's Avatar
Default What fender modification will be needed...
What fender modification will be needed to run nonstaggered 17x9 +35 WedsSport TC105N? I will be lowered on Espelir's.
Thanks in advance.
Old Jan 21, 2011 | 03:59 PM
muenchables's Avatar
yes
Old Jan 21, 2011 | 11:12 PM
aCab's Avatar
A lot. Fronts will need flared, and rears will need pulled...a lot.
I'd look into the 17x9 +49 version. rob.ok is selling a set over in racing and competition. $1200 I think. Much less required to run those.
Old Jan 21, 2011 | 11:15 PM
aCab's Avatar
here ya go:
https://www.s2ki.com/forums/index.php?showt...post&p=19007189
Old Jan 22, 2011 | 01:36 AM
LickyMYwalker's Avatar
those were sold a long time ago. i actually asked recently lol.
Old Jan 22, 2011 | 03:46 AM
So would I just need to roll the rear fenders to run 17x8/17x9 Offset+49?Would they be concaved at all? On a somewhat unrelated note, what offsets of Advan RZs would require minimal fender modification?
Old Jan 22, 2011 | 10:13 AM
Euroflavor's Avatar
if you run 245 on the 9"+35 you will need a full roll in the rear and depending on how much camber you want you can do a pull also. if you dont pull it then your looking at the 2.5/3-ish for camber out back
as for the fronts - again depending on the tire... trim the fender liner and get a nice roll and you should be good.
all this is relevant to ride height also.
Old Mar 8, 2011 | 12:12 PM
I Love My S2K.'s Avatar
What size tire would you recommend on a 17x9 +35 on the front without flaring the fenders? Im on Buddy Club N+ and want to run these sizes on all four wheels. I don't want to flare or pull any fenders. Is this possible? I don't mind running whatever camber I can using the OEM adjustment.
Old Mar 8, 2011 | 09:24 PM
Mar48's Avatar
fender pull would be recommended for all four corners unless you wanna run skinny tires + camber... Not sure how much camber you would need but if you do a search for "9+35" you will find out
Old Mar 13, 2011 | 09:36 AM
lman's Avatar
Sorry for thread hi-jack. but do i need fender mod for WedsSports TC105N 17x8 +42 front and 17x9+49 rear ? running 215/245 or maybe 255 rear.
