Wheel Fitment Guide
Old Sep 7, 2015 | 12:38 AM
  #1091
Manga_Spawn's Avatar
Site Moderator
Distance to the brake caliper changes with what face the rpf1 have. The convex face has tons of space for bigger brake. The concave face which is likely what you are looking at doesn't have any space hell it barely clears the stock brakes. There is tons of info on these wheels and huge thread in the gallery to help you.
Old Sep 7, 2015 | 12:54 AM
  #1092
s2000Junky's Avatar
Originally Posted by Amaritpal
I know nothing about wheel offset and sizes. it seems all very tricky to me. Today i was noticing how close the brake calipers are to the stock ap1 wheel. I had a thought that struck me, in the future id like to get some enkei RPF1's on my car with a wider tire size, BUT would a low offset like +38 in the front, would that have enough clearance on the brake calipers? and would the wheels and tires stick far outside my fenders because of the added width? maybe some 9's in the back and 8"s in the front. or 8.5's in the front and 9.5's in the back. i would be lowering the car on a coilover suspension at the same time. what would be a driveable offset for daily/spirited driving? what about track specs? any advice would be appreciated, thanks.
Yeah to build on what manga said. The convex wheel from the rpf1 line up is what you need for up front to clear a BBK. Either the 8 + 45 which is a common up size for the front which will accommodate a 225, or the one which I run which has even more clearance and width with the 8.5 +40. This wheel size is 13mm more aggressive and really requires a little bit of a fender pull up front to safely clear if you want to run reasonable camber. After the 8.5" it moves to the concave face at 9" and wider. The 9 +45 is the most reasonable rear option. 9.5 +38 can be done but its pushing it with a 255, rolling fenders and bumper relocate and -3 camber. 245 gives you a little more room to run less camber.
Old Sep 8, 2015 | 09:30 AM
  #1093
Amaritpal's Avatar
thanks for the help guys i appreciate it. I did not even know there is a convex wheel and concave wheel design to be honest. But i do like the look of the concave design. Im a student currently and its not easy to save up for wheels, suspension, engine parts and all that good stuff quickly. i work on the weekends and my car payment takes 50% of my monthly income. right now i want to do thorough research on what im looking for and when the money has been saved, i will definitely look back on your input to make the decision of what wheel specs i want to put on the car. thanks guys
Old Sep 9, 2015 | 07:02 AM
  #1094
SiClone's Avatar
Rears already rolled, but here's a potential set that just became available on Craigslist:
18x9.5 +43
18x10 +44
Old Sep 9, 2015 | 08:48 AM
  #1095
Site Moderator
Fronts definitely need a roll for those. For tires I would do 245 in front and 255 in the rear and you will likely need between 2.5 and 3 degrees of camber in front and about the same in the rear (probably closer to 3 in front and 2.5 for the rear).
Old Sep 9, 2015 | 10:19 AM
  #1096
SiClone's Avatar
Thank you my wheel master Manga_Spawn.
These rims not worth the trouble then…
Old Sep 9, 2015 | 03:12 PM
  #1097
Site Moderator
Curious what make of wheel they are? Those are decent specs and not ones I see very often.
Old Sep 10, 2015 | 09:12 AM
  #1098
SiClone's Avatar
Volk GT-7
https://minneapolis.craigslist.org/w...211173128.html
Old Sep 10, 2015 | 09:56 AM
  #1099
s2000Junky's Avatar
Originally Posted by SiClone
Volk GT-7
Looks like a good wheel and not a bad design, definitely would look good on someone’s S. Fronts are aggressive but with a little pull and some camber they should work well. Rear will sit pretty good with the normal fender mods. Make a perfect performing 245/255 stagger.
Old Sep 10, 2015 | 10:03 AM
  #1100
Site Moderator
Wow old school volks. Thats a good price and I haven't ever seen those specs before. Not a big fan of how they look but like Junky said it is a good performing wheel.
