Wheel Fitment Guide
Old Oct 2, 2015 | 11:17 PM
  #1121
JDMfrank's Avatar
Originally Posted by Manga_Spawn
It isn't a good match for the 10 inch wide wheel and it is also taller than the OEM. If you want 18's do 18x11 or 11.5 and a 295/30/18. Look up S2000Junky or Riceball's setup for offsets. If you are doing 10's a 255 is optimized on that width.
Think im pretty decided on going with the 18x10 with a 255/35/18. Wondering will the 255 tire sit nice and square on this setup or will it be stretched? from looking it up im seeing some stretched some not. maybe go with a 265 to be safe? i want zero or very close to zero stretch.
Old Oct 3, 2015 | 05:49 PM
  #1122
1nate7's Avatar
Provided you have the clearance, 265/35 would fit more square on a 10" wheel and provide the look you want.
Old Oct 4, 2015 | 12:42 AM
  #1123
JDMfrank's Avatar
Ill have to make them fit Thanks for the reply.
Old Oct 28, 2015 | 06:56 AM
  #1124
tekn1k's Avatar
Hi!
I'm really new to the world of S2000s, and what they can fit, but I have a question:
18x9.5 +38 all around, either a 245/35 or a 255/35 - The car would be very low, with max -3* of camber all around.
I understand this would be fine for the rear with a 245/35 or even a 255/35, but I am concerned about the fronts. I don't even own the car yet, I'm just collecting my thoughts and getting a game plan.
Thanks for any help!
Old Oct 28, 2015 | 07:32 AM
  #1125
DrakeValle's Avatar
Jaor was running 17x9.5+38 square on 255s before he got overfenders. You can see how it looks here, might be able to find his alignment specs as well: https://www.s2ki.com/s2000/topic/106.../page__st__375
Personally, his setup is a little lower and more aggressive than I would go (it still looks great though). They will "fit" with a roll and probably pulling (especially in the front). I say "fit" with quotation marks, because it depends on your definition of fit.
Old Oct 28, 2015 | 07:35 AM
  #1126
tekn1k's Avatar
So, in theory, a 18x9.5 +38 on the front would work relatively easily with a smaller tire size, no?
This is way too aggressive for me.
Old Oct 28, 2015 | 08:34 AM
  #1127
DrakeValle's Avatar
I wouldn't say that it's going to be "relatively easy". A smaller tire would provide some more clearance. Personally I think 9+45 is a much better setup on a stock fender car.
Manga is much better at giving wheel advice than I can.. but there are tons of threads out there regarding wheels/tires of all sizes.
Old Oct 28, 2015 | 08:56 AM
  #1128
tekn1k's Avatar
Well, thanks for your input. I'm new to these cars. I came from the Volkswagen world, so it's quite a bit different over there.
Old Oct 28, 2015 | 09:01 AM
  #1129
1nate7's Avatar
There is a 18 x 9.5" +45 available, that would be much better for the front. You could either run 9.5" +45 all around or pair them with the +38 rear for a more aggressive stagger look.
Old Oct 28, 2015 | 09:12 AM
  #1130
Manga_Spawn's Avatar
Site Moderator
9.5 +38 does not fit in front easily at all. Even with a 245 which will help a little bit but the wheel is very aggressive for the front. It can fit in the rear but still requires work. Front you'd need to pull the fenders a good amount and run -3 camber or more. Its not an ideal size for the front with OEM fenders.
